The FIAT Forum
Old 09-01-2007   #1
Trader Rating: (0)
Replace fuel filler tube without removing tank?
Hi all,
I have a leak that I'm pretty sure is the plastic tube that goes from the filler cap to the tank. Anyone know whether this can be changed with the tank staying on the car? Or will I be better off just biting the bullet and removing enough stuff to make room to work in?
It's wet and cold and it's dark when I'm not at work, and the tank is 2/3 full, or I would have lain under the car and figured it out for myself by now :-)
1995 Cinq 899
Blaupunkt Ontario
sweavo is offline
Old 09-01-2007   #2
Fehler in alle Teilen
Fivehundred's Avatar
Trader Rating: (0)
Fivehundred has donated! United Kingdom
Re: Replace fuel filler tube without removing tank?
You'll see the filler tube once you remove the bit of plastic wheelarch liner in front of it. It can be changed without removing the tank, but you will need something to dran the tank as the fuel will spill when you remove the hose.
Fivehundred is offline
Old 13-01-2007   #3
Trader Rating: (0)
grand! thanks, I'm attempting this today, wish me luck!
1995 Cinq 899
Blaupunkt Ontario
sweavo is offline
(T) 899cc Fuel Tank - AGGHHH!!! Sei-Mad Cinquecento / Seicento 19 10-10-2005 01:35
(G) Fuel tank leak with a twist Liam Cinquecento / Seicento 58 22-07-2005 17:43
(T) Cinq Fuel Tank\ Fuel Guage arseofbox Cinquecento / Seicento 0 25-09-2003 02:35
(G) is it the fuel pump or a blocked tank vent.. lashlondon Uno 8 24-09-2003 20:58
