| timing belt wife broke down in her cinq yesterday morning,she said a light came on and engine just died,she phoned green flag and mechanic reckons it timing belt,but some fiat engines when this happens are knackered others arent,is this engine caput?
| | #2 | |||||
| Fehler in alle Teilen | Re: timing belt
| | #3 | ||
| Re: timing belt
| | #4 | ||
| custodian of imola blue | Re: timing belt Replace the pulley bearing while you're at it: it'll be fine.
| | #6 | ||
| Re: timing belt My wifes did the same the other week, was a relative painless task altohugh all the guieds fail to mention the following tools required cup of tea...and brought to you hot and steaming without the need for you to ask wife on hand to swear at a small child with ricketts to do up the alternator pinch bolt
__________________ ![]() | |||
| | #7 | ||
| Re: timing belt GOT A MECHANIC PAL DONIG IT ON SAT, is donig timing belt+head gasket £66 for timing belt,water pump and tensioners and £30 for gasket set and £50 to fit it iam happy
| | #8 | ||
| ' | Re: timing belt Why the HG and pump, has that gone as well
__________________ Black Seicento Sporting mk2 1242cc 16V conversion finished and removed! ![]() Megasquirt installed, a constant evolution 1368cc and 6 speed running great now ![]() My Members Motors thread ![]() | ||
| | #9 | ||
| custodian of imola blue | Re: timing belt Probably worthwhile doing the water pump while in there, but unless the headgasket is blowing, I can't see the logic in replacing that.
| | #10 | ||
| Re: timing belt actually top of housing where gasket goes is cracked(looks like someone tightened it to hard) and is leaking oil so its being reapcled,he,s donig water pump also
| | #11 | ||
| mad bad and very very old | Re: timing belt Are you sure your not confusing the heagasket with the rocker gasket? Cheers D
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #12 | ||
| custodian of imola blue | Re: timing belt Sounds like rocker gasket 2 me 2.
| | #13 | ||
| Re: timing belt
| | #14 | ||
| ' | Re: timing belt Rocker cover gasket is not £30 and takes 15 mins too fit, and is nothing to do with HG or water pump. I just don't want you to do the HG and pump if there's no need. They may go wrong afterwards lol, when they were fine before. if the "top of the housing" is cracked, then a gasket will not help anyway. IF its cracked about the HG, then you have a cracked head!!!! If the rocker cover is cracked, its a LOT cheaper, and can poss be bodged without replacement. Post up a picy of your "HG" crack and oil leak. Not trying to be a dick, but don't want you to get stuff done thats just plain wrong. Kristian
| Timing Belt Replacement | lightweightmick | Panda (Classic) | 14 | 21-03-2008 12:40 |
| | Wiped | Punto | 5 | 27-08-2006 21:30 |
| | punto85 | Punto | 4 | 31-03-2006 19:25 |
| how to change a timing belt.. | christopher watson | Panda (Classic) | 10 | 02-01-2006 21:29 |
| | fixitagaintomorrow | Marea | 0 | 01-02-2005 14:20 |
