| Sporting Front Strut I've just removed my Cinq sporting front strut & to my dismay the spring pops out as soon as the strut top nut is undone. I'm having trouble refitting the strut. The spring compressors seem to prevent the strut from fitting back where it should. What's the best way to refit the strut?
| custodian of imola blue | Re: Sporting Front Strut Dear God -- I've heard of people doing themselves serious injury doing it like that. The proper way to do it is addressed in one of the guides here. But, in brief: loosen the top nut but do not undo. Remove strut/spring assembly intact from the car, compress the spring with spring comressors, undo top nut, release compression on spring. Assembly is the reverse of disassembly. Do it on the bench, not on the car!
| | #3 | ||
| Erm........... | Re: Sporting Front Strut I'd split the bottom balljoint, split the track rod end, undo the clip on the big end of the inner cv boot, pull the strut off, rebuild carefully on the floor, making sure the spring compressors don't move as you tighten them as a compressed spring breaking loose will remove your head in a very quick and messy manner. Refitting is the reverse of removal
__________________ Dirty Yellow Box | ||
| | #4 | |||
| mad bad and very very old | Re: Sporting Front Strut
Cheers D
__________________ If it has pistons or tits, its going to be expensive. | |||
| | #5 | ||
| Re: Sporting Front Strut I've seen the post & realise what I've done I need to undo the 3 nuts holding the strut top & then rebuild it all & refit to the car
| | #6 | |||||
| | #7 | ||
| | #8 | |||
| ' | Re: Sporting Front Strut Bah, bloody double post! I'm sure you all said it before, but i typed it up for the other thread, and am not gonna waste my precious time ![]()
__________________ Black Seicento Sporting mk2 1242cc 16V conversion finished and removed! ![]() Megasquirt installed, a constant evolution 1368cc and 6 speed running great now ![]() My Members Motors thread ![]() | |||
| | #9 | ||
| Re: Sporting Front Strut You shouldn't remove the shock nut until the whole shocker is off the car. You should only undo the three mounting nuts before removing the shocker as a unit. Put the compressors on the spring and wind them down as far as you can, then re-assemble the top section of the shock and put the nut back on and give it 3-4 full turns (make sure it cannot come lose). then refit the shocker. Once back in place tighten the top nut.
__________________ ™Đę√їǾŪ§¯Đę√їŁ™ | |||
