| | #16 | ||
| Erm........... | Re: Argh! Bl**dy Cinq! Nope, no injector light, not even a flicker.
__________________ Dirty Yellow Box | ||
| | #17 | ||
| Erm........... | Re: Argh! Bl**dy Cinq! Frenchwood, I thought that you weren't supposed to separate the TPS from the throttle body as it had to be set up or something?
| | #18 | |||
| Re: Argh! Bl**dy Cinq! Basically the TPS is a resistor. At low revs the resistance is less than high revs. So if the bottom half of the switch has had it, low revs & tickover will misfire as the ECU tries to compensate for the lack of signal. Usually when the ECU is compensating, the car runs REALLY rich and so chokes itself out a lot, hence the rough running, and almost impossible tickover (the idle stepper motor has to work overtime!!). When you floor it, the TPS works at the top end, send a clear signal and wham, the ecu knows what to do, and so it works fine. You'll tend to find that driving over 3000rpm is fine, provided you are constantly accelerating. if you hold throttle position it will start to kangaroo. You'll also notice occasionally, that the Injector light will come on. This is because the ECU is running the engine too rich and the lambda sensor reads unburnt fuel, the ECU then compensates again and the car starts to lurch, the light goes off, the ecu thinks it's fine and so it over-compensates again. Et-Voila, you have a nice little cycle of crap fueling which will: a: empty your pertol tank really quick. b: Kill the catalytic converter c: wind you to the point of wanting to scap the car. It really sounds dead like the issue i was having. It's worth the £30 i paid for it as it was an instant fix that took literally 5 mins. If i were you, i'd give it a go.
Hope that helps.
__________________ ™Đę√їǾŪ§¯Đę√їŁ™ Last edited by frenchwood; 04-01-2007 at 01:16. | ||||
| | #19 | ||
| | #20 | ||
| Re: Argh! Bl**dy Cinq! In my experience - No. The gasket gives way. Anyone had experience to the contrary? cheers & Good luck
__________________ ™Đę√їǾŪ§¯Đę√їŁ™ | |||
| | #21 | ||
| Erm........... | Re: Argh! Bl**dy Cinq! OK, changed the TPS today, no difference though Also changed the injector for another one with good o rings, Also changed the crank postion sensor. It's making me re-think giving up smoking
| | #23 | ||
| | #24 | ||
| | #25 | |||
After a reset, the ECU will run "rough" for about the first week or so. If it's not working properly on tick-over then the ECU has to guess at the fueling on tickover, and may cause problems. Try swapping it out! If you need a new one though it's a FIAT only part. Other than that, it could be a dodgy ECU.
__________________ ™Đę√їǾŪ§¯Đę√їŁ™ | ||||
| | #26 | ||
| | #27 | ||
| Re: Argh! Bl**dy Cinq! Good luck to ya mate! Let us know how you get on!
| | #28 | ||
| Moderation in Moderation | Re: Argh! Bl**dy Cinq! be interesting to hear how you got on too p.s. dont suppose you have yellow bumpers going spare?
__________________ Lots of mods Rev1 MR2 Turbo - Sold pending collection RX7 Twin Turbo - Because real men play with twins | ||
| | #29 | |||
Sorted it on Saturday Feel a bit of a retard though Read so many times on here to check for sparks jumping when dark Changed the map sensor, didn't make the slightest bit of difference. Been wondering if the inlet manifold gasket was leaking so sprayed duck oil liberally on the inlet manifold, whoosh, ball of flame under the airbox, blew it out, thought about it for a bit, did it again with the same result. Listened carefully and could hear the clicking of spark twixt plug and head Changed the leads, which are about 3 months old, thought I'd cured it, hadn't, Took #3 plug out to find 2 dirty great cracks down the porcelain. Must have been a bit heavy handed when I swapped them from old engine to new Just assumed that cos they were only about 2 1/2 months old it wouldn't be them and it must have been something I'd done when I was swapping the engine What a retard! On the plus side, it's quicker and more responsive than the old engine and I now have synchro on 2nd gear which is a vast improvement. I've got 1 yellow sporting bumper but it has had the o/s/f corner repaired and primered.
__________________ Dirty Yellow Box | |||
| | #30 | ||
| Re: Argh! Bl**dy Cinq! lol... Nevermind, at least you know it works now!!
