The FIAT Forum
Old 17-12-2006   #1
Trader Rating: (0)
Sciento wont start!!!
Hi there!
I recently bought an 'S' reg Sciento sporting as a project. Main problem is it doesnt start. it had been stood for 4 months and when the previous owner tried to start it it wouldnt. i have swapped most of the sensors, coil packs even the injector from a scrap punto but it still doesnt start. i cant get my head round it... timing is right, compression is good, fuel pump works, good spark at the plugs. i've reached a hurdle at the ecu. could this be the problem? if i turn the ignition on and off about 5 times i can get it to fire sometimes. not very often but once its running it runs fine! took it for a drive and it is great! when you try to start it from 1 turn of the ignition it tries to fire, just the spark seems to late. almost like the it is retarded too much?????? i do not have the red key. looking at other forum q's i dont think this is the problem... just givin you a heads up on the situation. any help will be appreciated! cheers, Matt
m_loades is offline
Old 17-12-2006   #2
Moderation in Moderation
GhostWKD's Avatar
Trader Rating: (0)
GhostWKD has donated! United Kingdom
Re: Sciento wont start!!!
fuel filter maybe?
sounds like its a fuelling problem, like when you start a lawn mower you're effectively priming it by turning key few times then starting, as that feeds petrol in at the turn of the key... so i'd say either fuel filter restricting most of it so it trickles through, or a sticky relay maybe (take it you get the whirrr when you turn the key to first stop bit?)
defo start at fuel filter for me though
Lots of mods Rev1 MR2 Turbo - Sold pending collection
RX7 Twin Turbo - Because real men play with twins
GhostWKD is offline
Old 17-12-2006   #3
Trader Rating: (0)
hi,
thanks for the reply, i have got fuel at the throttle body (took the pipe off and it poured fuel through when i turned the key. once the car starts it revs up to 5000rpm quite happily! if there was a fuel problem wouldnt it cough and splutter?
cheers
m_loades is offline
Old 18-12-2006   #4
GhostWKD's Avatar
Trader Rating: (0)
it may be that there is fuel but not enough fuel pressure, if timing is right and a good spark its the only thing it can be does it throw up any warning lamps at all? (injector warning light or anything?)
GhostWKD is offline
Old 18-12-2006   #5
Bravo 1.8 HLX FTW
The Sultan's Avatar
Trader Rating: (0)
The Sultan has donated! United Kingdom
the 899cc engines had a comon problem with the rpm sensor wiring caching on the alternator belt
i'm guesing it is a 1242 from the punto ecu swap thou
The Sultan is offline
Old 18-12-2006   #6
frenchwood's Avatar
Trader Rating: (0)
Sounds like it could be the cold start function playing merry hell and not giving enough fuel.
What motor is in it and what mods?
If it is the ECU it's a pain in the ass to swap because of coded key - You'll need the lockset too!
Could be fuel return... ie not enough pressure on the fuel line which is causing it to run lean until you effectively flood it. Have you swapped out the Fuel relays? if not give it a go, as a weak electrical signal will screw up the fuel at TB even if you are getting fuel at initial prime.
™Đę√їǾŪ§¯Đę√їŁ™
Black Cinq Sporting SOLD Gone but not forgotten!
Replaced with a V6 Monster!
frenchwood is offline
(G) Brava automatic cold start noise btomic Bravo / Brava 21 19-12-2006 10:27
(T) Brava - cold start problems. silverArrow Bravo / Brava 3 31-10-2006 09:51
Diesel engine wont start on the fiorino christopher watson Fiorino 4 01-10-2006 20:49
(G) Punto 55 SX won't start - please help shoelover Punto 5 09-09-2006 19:05
(T) Fiat Punto 55 start up problem inayat Punto 4 19-08-2005 15:58
