| Vibration from the dash Help! I've had my Seicento Sporting for about 12 months Know, But there's been a lot of vibration that makes a lot of noise through the dash board when sitting staionery and every time I take it to a garage they don't know what's wrong. So far i have had the engine mounts changed but its made it worse. I know it had a bump cos there's matt black paint on the inside just under the passenger window and lovely shiny black paint everywhere else. I'm thinking about selling it but I love the car too much can anyone shed some light on this? JiMMy
| my dash vibrates all over the place - - - but only at 100mph+ - - - stationary she is sweet as can be how old is your sei? SEI-POWER
| | #3 | ||
| well, ive got a rover 214si that ill swap u for it :) its an ex write off, had a damaged door ( changed it ) and a broken drive shaft ( changin it 2day ) all i gotta do after that is fix the exhaust then it off to the mot center :) ![]() Aragh! vroom Vroom
| | #4 | ||
| It's only a 1998 car with 24000 on the clock[?] JiMMy
| | #5 | ||
| lol worth a try :p ( its a J reg ) ![]() Aragh! vroom Vroom
| | #6 | ||
| thats good mileage for 5 year old!!! i have 13000+ on mine and its a 2001 model as for your problem i have no idea m8 ;) SEI-POWER
| | #7 | ||
| Cheers any Way JiMMy
| | #8 | ||
| Donz, Get your wheels rebalanced. Mine used to shake at 95+, then I swapped the wheels front to back and got mega steering wheel wobble. The monkeys who fitted my tyres (won't go there again) hadn't balanced the back ones properly. Had them redone at a reputable place and now smooth all the way up to 117! hee hee!! Pete. Cinq sporting 1242cc http://mysite.freeserve.com/close_to_cracking_up/
| | #9 | ||
| yeah i need to get my pressures checked too - but tbh i rarely go above 40 - but i'll get it all done for coming down to the meet SEI-POWER
| | #10 | ||
| If anyone reads this could you tell how many RPM your seicento idles at mines just below 1000 and when rest I my foot on the accelerator and put the revs up a bit the vibration stops?????????????[xx(][xx(][xx(][:(!] JiMMy
| | #11 | ||
| odd, mine idles at slightly below 1000 too, does yours stall if you leave it idling? SEI-POWER
| | #12 | ||
| anyone know how much balancing costs? mine is pulling to the left quite a bit and when I go over biggish bumps the steering feels awful light and sometimes kind of skids out. G grahaml@motability.co.uk
| | #13 | ||
| They should idle at 900rpm or so when warm. Graham, if it pulls to the left, it could be bad rear brakes (one side dragging) which is not a new thing for Cinqs and Seis. Alternatively, it could be sticky front brakes caused by a bad caliper, or uneven tyre pressures. If you have a different make of tyre on each side this could do it too. Don't want to start listing things like crash damage though [:0] Wheel balancing stops shake, usually most felt at 65 mph and 90+ on mine. It doesn't make the steering pul to one side. Pete. Cinq sporting 1242cc http://mysite.freeserve.com/close_to_cracking_up/
| | #14 | ||
| Cheers Pete, you are indeed the Fiat Guru! It might well be the front tyre - I am running Good Year Eagle Touring all round but got a puncture the other day and had to settle for a cheapo "Nankang"!!!! I'll swap it for one of the backs and see if it makes a difference. You din't happen to see my post about the noise I got going on at the moment when the clutch is dipped and the engine warm? any ideas on that one? Cheers Graham grahaml@motability.co.uk
| | #15 | ||
| Yeah, I didn't reply as I think RiB has hit the nail on the head - new clutch time. [V] Pete. Cinq sporting 1242cc http://mysite.freeserve.com/close_to_cracking_up/
| | Little Red Devil | Cinquecento / Seicento | 21 | 02-11-2007 18:34 |
| | CHARLIE-CINQ | Cinquecento / Seicento | 17 | 25-12-2006 01:35 |
| | jmarson | Cinquecento / Seicento | 10 | 30-03-2004 01:19 |
| | RoadRunner | Punto | 2 | 18-02-2004 00:40 |
| >> Fitting a in dash TFT?? | Dank_army | I.C.E | 3 | 04-01-2004 02:11 |
