General christmas for Chii
arc
this is where i stand
Manchester
It's time. Got some things to do to the car over xmas. Tax ran out, so she's now safely in the garage (and already in bits)
Evening 1
First of all, decorating the garage is important.
and then remove the battery, cutting off the terminals (battery is on the move)
emptying the boot
and then empty the car
and look at all the stuff that came out of it!
and some of the ICE - bet this stuff slows the car down a bit!
GhostWKD said:
Wooo :D (y)
let me know how battery in boot goes its something i want to do to mine really :eek: :D
Its dead easy to do. Use a bulkhead fitting and attach the existing battery wiring to it on the engine side. Then run a new cable from the battery box to the habaticle side. Earth the battery straight to the shell, and Robert is your mothers brother.
D
35mm Would be ok. I use 50mm on Emergency back up batteries with a draw of 180 amps at 110 Volts dc. This would be continual load for up to 2 Hrs where as yours is short term load for starting only.
