The FIAT Forum
Old 26-11-2006   #1
Trader Rating: (0)
Crank Sensor
I know this may sound like a real stupid question...but does anyone know an easy way of removing the crank sensor, as im doing a punto conversion on my cinq and its being a bi**h to get off i was going to use the crank pulley as a lever using a screwdriver but was worried bout damaging them.
Also will the punto loom work on the cinq (Moving the cinq ECU) as mine is all ready connected and would be a shame to have to unplug it all!!
THANX
wingnut2k5 is offline
Old 27-11-2006   #2
arc
this is where i stand
arc's Avatar
Trader Rating: (0)
arc has donated! United Kingdom
Re: Crank Sensor
remove the screw, and the carefully wiggle it out. can take some time. dont lever it, you'll snap things.
can't use the punto loom, ecu ends up in the wrong place. stop being lazy and just unplug it all
(welcome to the forum too btw)
arc is offline
Old 27-11-2006   #3
umop apisdn
balidey's Avatar
Trader Rating: (1)
balidey has donated! United Kingdom
Re: Crank Sensor
When you have the bolt out, try turning the sensor a bit, this will loosen it and then should wiggle out.
Your sister is hot, but your mum does that thing with her tongue
balidey is offline
(G) I need a crank sensor Jetsfan5 Cinquecento / Seicento 14 27-06-2006 18:46
Tempra 1.6 SW Crank Sensor BrianM Tempra 3 17-06-2005 19:56
(T) Crank Sensor??????????? vman Marea 0 28-09-2004 10:39
(T) Crank Case sensor ????? oaksey Marea 4 01-09-2004 15:39
