well the cinq 1108 head has 1mm larger inlet valves, so that'd be a better head. but you'll never feel the difference, so both are as good as each other as D has said
unless its off a 1242 176.B4 engine.. (post may1997) then it has the same size inlet valve, and possibly the '866' cam as found in punto75's - so that'd be better if buying a complete head.
