The FIAT Forum
Old 19-11-2006   #1
Dave lee's Avatar
Trader Rating: (0)
warm start problem
Hi fellow Fiatmen
I have a 1998 Seicento 1.1 that has developed an annoying problem. The car starts ok from cold & is ok when hot if re-started straight away - but takes 6 or 7 trys if the car is left for 10 mins or so. Fiat replaced the pipe to the map sensor which didn't do much good. I will have to take it back to Fiat if all else fails but as they have failed once, I am trying to work it out myself. I have no warning light or fault codes stored. any suggestions welcome.
Dave
Dave lee is offline
Old 19-11-2006   #2
Scandinavian Passion....
StoneNewt's Avatar
Trader Rating: (0)
StoneNewt has donated! United Kingdom
Re: warm start problem
how old is the battery? warm starting can be a battery related problem...
Daily Driver: Seicento Sporting, Dark Grey, MPI 1108cc 8v, stock externals
Track Day: Seicento Sporting, Yellow, High Boost 1247cc 8v, Factory Abarth body kit
Luxury Liner: Volvo V70 D5 Sport, Black, chipped & uprated intercooler, V70R body kit
StoneNewt is offline
Old 19-11-2006   #3
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Eh... I presume the car is turning over, just not starting.
If this is the case, then once it has failed to satrt, whip a plug out. If there is a whif of fuel then its a lack of spark, if there is no fuel then it will be a fuel related issue. When was the fuel filter last changed? Can you hear the pump prime when you turn the ignition on?
D
rallycinq is offline
Old 19-11-2006   #4
StoneNewt's Avatar
Trader Rating: (0)
Both Punto and Sei suffered from turning the engine over but not catching when warm, twas that the battery was giving up when it got heated up. Cold starts were fine and hot starts were okayish, but warm were a total nightmare...
Old 19-11-2006   #5
rallycinq's Avatar
Trader Rating: (1)
OK, I can't see how that happens unless its an earthing issue.
D
Old 19-11-2006   #6
Dave lee's Avatar
Trader Rating: (0)
Thanks for the advice chaps. I will be getting the battery & earth lead checked + new fuel filter.
Dave lee is offline
intermittent start problems with Tipo 2.0 16v goran Tipo 4 26-04-2006 11:35
(T) Warm Engine - No Start frozensolid Punto 3 07-09-2005 09:23
(T) Fiat Punto 55 start up problem inayat Punto 4 19-08-2005 15:58
(T) Strange noise and start up problem. El Greeno Uno 18 23-02-2005 10:47
Mid-throttle injection problem in Lancia Y10 FatNote Panda (Classic) 26 30-07-2004 18:58
