| help save my cinq !!! valve problem First post, so apologies if this is in the wrong place ! Took my car to the garage as it seemed to be 'missing' for a second or two when accelarating. Bad news they said, at least one of the valves has gone, and to replace this I am looking at least £300, but they would need to remove the cylinder head to be sure. They also said bear in mind my car has 8 valves, so if any of the others need replacing, then the cost will go up. To be honest, I don't even know what a valve is... lol. But does anyone know if this cost sounds about right? I don't want to give up on my beloved cinqy just yet, so any advice will be appreciated ! XXX
| Re: help save my cinq !!! valve problem That sounds about correct to be honest inlcuding labour, as with a lot of things, its the labour that costs, the parts are not too expencive for that kind of work. Its about the same price for a garage to sort a head gasket which involves taking the head off etc. The valves are located in the head (top part of engine) which basically control the fuel/air into the engine and burnt (used) gases out of the combusion chamber which go out your exhuast pipe!
| | #3 | ||
| meow | Re: help save my cinq !!! valve problem £300 would buy a second hand engine, and have it fitted at a garage and fully serviced with timing belt. and if its a sporting you could even get the 1242 engine fitted
__________________ [b]Next car? punto again? ![]() Long term project car- Punto 55 Previous car- Uno turbo | ||
| | #5 | ||
| Re: help save my cinq !!! valve problem Not sure what tests they did I'm afraid. Is it worth taking elsewhere for a second opinion or just go with what they say. I just wondered whether they saw me coming, and were taking the p*** !!! I only paid £500 for it back in Feb, so I don't really want to end up paying more than what it's worth, even though it's in real good condition - apart from the damn valve !!! Thanks for the explanation on what a valve is !
| | #6 | ||
| Moderation in Moderation | Re: help save my cinq !!! valve problem is it a sporting or a non sporting? i'd say its definately worth getting a second opinion, does it throw up any warning lights at all on the dash or anything?
__________________ Lots of mods Rev1 MR2 Turbo - Sold pending collection RX7 Twin Turbo - Because real men play with twins | ||
| | #8 | ||
| Re: help save my cinq !!! valve problem It's an SX, non sporting. There are no warning lights, just a 'missing' sensation when I accelerate, as I said earlier. I'm in Swindon (for my sins!!) Thanks for all your help.
| | #9 | ||
| Moderation in Moderation | Re: help save my cinq !!! valve problem hmm, could be any number of things, personally not too familiar with the 899 engine/management though cant even remember if they're injection or carb'd
| | #10 | ||
| Re: help save my cinq !!! valve problem Some of the very early models had carb (non uk to my knowlege), but apart from this should be fuel injection all models. Definately as with most jobs worth "doing some shopping" on a best price!
| | #11 | ||
| Moderation in Moderation | Re: help save my cinq !!! valve problem still dont think thats enough to diagnose it as valves... did they say how they got to that conclusion? think the 903's were carbs (aka pre s/sx/sporting guise) then 899 injection, just wasnt 100%
| | #12 | ||
| Re: help save my cinq !!! valve problem No, they didn't explain anything apart from the 'cylinder head' will have to removed to be sure. (whatever that is !) I will defo take it elsewhere for a second opinion, otherwise you may see it appearing on ebay soon !
| | #13 | ||
| Moderation in Moderation | Re: help save my cinq !!! valve problem Tbh, definately sounds a bit of a drastic assumption to me hopefully it'll be something alot easier to fix Oh and welcome to the forum by the way
| | #14 | ||
| __________ | Re: help save my cinq !!! valve problem jamie is in swindon he any good with diag? mean while try a bottle of add to the petrol tank injector cleaner. when engine is running and its dark look under the bonnet and see if there are sparks jumping around on the out side of any wires
__________________ Binki | ||
| | #15 | ||
| custodian of imola blue | Re: help save my cinq !!! valve problem I'm very suspicious. I think it may be electrical or simply that the car needs a decent service (plugs, oil and air filter, oil, maybe plug leads). It doesn't sound like a valve problem to me. How reputable is this garage? Easy way would be to take the beast in to a Fiat dealer and get them to take a peek. Once they've told you what the problem is you can either let them quote to fix it or pay them for the diagnosis and walk away.
