The FIAT Forum
Old 14-11-2006   #1
JR
Trader Rating: (0)
Italy
12v Accessory hook up.
I have an accessory for my Sei which needs to be wired into the 12v electric supply. What would be best from peoples experience as a splicing point baring in mind its not one of these simple plug into cigar lighter jobs!! something like the cigar lighter power supply or something?? I don't want to pick anywhere where the supply is not strong/good. Be similar for the supply to an alarm or something at a guess, but not sure??
Sorry electronics are not my strong point.
Many Thanks
JR is offline
Old 14-11-2006   #2
oh me gums!
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: 12v Accessory hook up.
well you havent told us what it is so cant say if 'it' would be strong enough.
if its neons or the like the lighters fine
custard is offline
Old 14-11-2006   #3
JR
Trader Rating: (0)
Italy
Its only for a little dash light so doesn't need that much just says "wire into 12v vehicle supply"
Which one is the 12v wire for the cigar lighter? or is there only one leading to the lighter itself??
Are there any other poss locations inside the car.
JR is offline
Old 14-11-2006   #4
MrDT's Avatar
Trader Rating: (0)
In the mk1 punto there are three wires, red, black, and yellow.
Black and yellow is what ps2, tft, and laptop are running off in mine. If you've got a haynes manual, the ratings and wiring diagrams should all be in there If you haven't, get busy with a multimeter
Ciggie lighter was safest bet for me, I blow a fuse and I lose my clock and courtesy light, not the end of the world. Since electricals are hardly fiats striongpoint though, i'd double check, don't want to lose your headlights at night!!
Makes sense to me that the ciggie circuit is a pretty safe bet though, it's designed for numpties to overload really isn't it
Mk1 Punto SX 60
Mutant MT1105USB, FLI Trap Active 12, Clear Indicators and Side Repeaters...
Custom satnav/dvd/mp3 car pc planned!
MrDT is offline
Old 14-11-2006   #5
JR
Trader Rating: (0)
Italy
Lol my thinkings exactly will just use black or yellow wire from cig lighter or something and splice it off of it.
Cheers.
JR is offline
Old 15-11-2006   #6
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
Ciggy lighter is fine, except if you want to be able to use the light with the ignition off. Certainly on the Sei, probably on the Cinq, there's no power to the ciggy lighter with ignition off.
fingers99 is online now
Old 15-11-2006   #7
MrDT's Avatar
Trader Rating: (0)
If you splice into the wires connected to the lighter, can't you get a constant 12v feed? If there are three wires, they should be ground, live, and switched live (i.e. only on when ignition is on).
Punto wiring threw me for a loop, i think the switched was red, and the constant yellow. I'm pretty sure that's the wrong way round!
Mk1 Punto SX 60
MrDT is offline
Old 15-11-2006   #8
JR
Trader Rating: (0)
Italy
So in this case which colour wire do i need to splice into for the cigar lighter power supply??
I don't mind if it works with/without ignition on.
JR is offline
Old 15-11-2006   #9
MrDT's Avatar
Trader Rating: (0)
First things first, i'd disconnect the wiring from the ciggie lighter unit. It should terminate in a little block that is secured to the lighter unit, it should be removed be pushing in the little retaining clip and pulling it out gently but firmly.
After doing that, come back and tell us how many wires are connected to that block, and what colours they are.
I just want to check: you do intend to cut these wires, solder this dashlight (got a link to what this thing might look like?) inline, and then hook the lighter socket back up right?
The way you said you'd wire it to either the black or the yellow wire worries me a little, you realise that you need a live and ground wire right? Do you know anyone with a 'multimeter' you could borrow?
Mk1 Punto SX 60
MrDT is offline
Old 15-11-2006   #10
JR
Trader Rating: (0)
Italy
Yes it comes with an earth wire which i'll connect no problems. Just wondered about the actual 12v supply for it thats all.
Could I not use a connector block or something where i split the wire into the light supply from the lighter supply?
JR is offline
Old 15-11-2006   #11
MrDT's Avatar
Trader Rating: (0)
A choccy block would be a good option
Snip the ciggie wires, stick each wire into a seperate segment on the lower side, then screw the twisted ciggie socket and dashlight wires to the same segments from the other side, saves soldering, good point
Mk1 Punto SX 60
MrDT is offline
(T) How to mount a towing hook? fredand44 Punto 0 28-06-2006 11:16
Getting 12v cable through the firewall for amp install SpazVan Multipla 1 15-05-2006 00:11
Placement of 12v (lighter) socket Soepy Panda (New) 18 13-04-2006 23:00
(T) Creating a + 12V ignition wire for my radio chrissmith Uno 12 28-04-2005 05:17
could i hook a laptop upto a 12v amp supply gaz.d I.C.E 9 24-10-2004 21:11
