The FIAT Forum
Old 13-11-2006   #1
keirk's Avatar
Trader Rating: (0)
Unhappy MOT .... How much will all this cost?
Hey guys,
Hows tricks? Just had my sei MOT'd and it failed...
It failed on:
  • Both of the front suspension (one is broke, the other is breaking)
  • one of the rear brakes low reading
  • Dimmed light too low (think they might need replacing)
Could someone let me know how much I might expect to pay for this at a garage? Don't expect a proper quote or anything just a good guess?
Just before Xmas as well boo!
Cheers chaps!
Brum! Brum! Beep! Beep!
keirk is offline
Old 13-11-2006   #2
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Re: MOT .... How much will all this cost?
Firstly, What bit of the front suspension has failed?
Rear brakes low, half an hour if its just adjustment, but when were they last serviced?
Does yours have electric adjustment or are they on the loaded setting?
D
rallycinq is offline
Old 13-11-2006   #3
keirk's Avatar
Trader Rating: (0)
Dunno, they just said the one of the front suspension units was leaking and other was totally deflated.
Last serviced a year ago - "electric adjustment or are they on the loaded setting" - dunno mate? Its a 2000 W-reg sporting if thats any help?
Cheers!
keirk is offline
Old 13-11-2006   #4
David C's Avatar
Trader Rating: (0)
That would be the dampers then.
Start from about £50 / pair + fitting (probably 2-3 hours)
David C is offline
Old 13-11-2006   #5
TruBlu
blu73's Avatar
Trader Rating: (0)
blu73 has donated! United Kingdom
You'll have electric adjustable units then like me.. On your dash, left of the steering wheels behind the indicator stalk theres a round switch thing with 0,1,2 and 3. Make sure that is set on zero.. If it is set on another the lights will be pointing down a bit (this is for when you got a big load in back which would lower the back and thus raisee the front meaning lights are wrong). So check that isn't the fault first as it maybe that nothing is broken.
blu73 is online now
Old 13-11-2006   #6
MG ZR Owner :)
SkinzCinqSporting's Avatar
Trader Rating: (2)
SkinzCinqSporting has donated!
I had this problem until last night, basically the manual adjuster had come loose and would no longer hold causing the lens to fall down, luckily my glass was coming away so I took the headlight apart and araldited the adjuster back on and now have reasonably adjusted headlights
SkinzCinqSporting is offline
Old 15-11-2006   #7
keirk's Avatar
Trader Rating: (0)
Cheers for the replies.
I've just called Kwik Fit about the suspension and I have a few questions for you knowledgeable types ;-) :
- dampers and 'shocks' are the same thing right?
- They quoted a fitted price of either £70 or £90 depending on the type either gas or oil - which would it be?
- They also said I should have a wheel alignment done (at £49?!) - is this right?
Plan to have a go fixing the light myself at the weekend.
Cheers!
keirk is offline
Old 15-11-2006   #8
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
The stock fitment is oil. I'd get another quote, but £70 doesn't sound too bad.
Very strictly, yes. If you don't undo the track rod ends you can get away without it. Try a backstreet garage. Same for the brakes. Take the failure sheet in.
fingers99 is offline
Old 15-11-2006   #9
David C's Avatar
Trader Rating: (0)
yes
David C is offline
Old 15-11-2006   #10
rallycinq's Avatar
Trader Rating: (1)
Coloquially(sp) Yes, technically, No.
David
Old 15-11-2006   #11
keirk's Avatar
Trader Rating: (0)
Huh?
keirk is offline
Old 15-11-2006   #12
rallycinq's Avatar
Trader Rating: (1)
In purely technical terms the spring absorbs the shock and the damper damps the occilations.
However. most people refer to dampers as shock absorbers,
D the pedant
Old 15-11-2006   #13
Turbo MPI Seicento
gazzaman2k's Avatar
Trader Rating: (0)
gazzaman2k has donated! United Kingdom
Cheers!
£70 is a very nice price if thats for both sides
Project Seicento
gazzaman2k is offline
Old 15-11-2006   #14
kritip's Avatar
Trader Rating: (3)
kritip has donated! United Kingdom
Where you based, I have a full set of used but good 51 (40K) sporting suspension just sitting in the garage.
Kristian
Black Seicento Sporting mk2
1242cc 16V conversion finished and removed!
Megasquirt installed, a constant evolution
1368cc and 6 speed running great now
My Members Motors thread
kritip is online now
Old 16-11-2006   #15
keirk's Avatar
Trader Rating: (0)
Thanks mate, but it's in the garage now being sorted.
Originally Posted by gazzaman2k
£70 is a very nice price if thats for both sides.
No, Kwik-Fit (the sharks) didn't tell me that on the phone. But on double checking it was each - so £140 for both sides.
It's gone to my old local garage (now it's a 35 miles away!) - who are doing the work and have said they will throw in a free MOT for me. It pays to be loyal
keirk is offline
Common MOT failures for a Panda panda type thingy Panda (Classic) 11 17-05-2006 17:22
(G) Mot Prices werdna Marea 6 21-04-2006 16:27
Mot nejones Ulysse 1 24-02-2006 13:22
(G) Seicento failed mot GhostWKD Cinquecento / Seicento 7 12-01-2006 00:43
(T) Mot Failed - Play In Both Rear Arms JohnRussell Punto 5 14-01-2005 18:46
