| Turbo MPI Seicento | TB breather pipes and oil breather on turbo car? hi just wondering how do i go about piping these up? on the back of the throttle body there are 2 little 4mm tube bits that suck air in when started and the oil breather blows air out. how do i go about piping these up? i have a little KN filter to go onto the oil breather but what do i do with the other 2 little sucker bits on the TB? cheers gaz
__________________ Project Seicento | ||
| MG ZR Owner :) | Re: TB breather pipes and oil breather on turbo car? Oil breather filters are now an MOT failure
| | #3 | |||
| Turbo MPI Seicento | Re: TB breather pipes and oil breather on turbo car?
__________________ Project Seicento | |||
| | #5 | ||
| Banned | Re: TB breather pipes and oil breather on turbo car? if it still falls within the required emissions then they wont fail you for it. babzs car went through the MOT with it and although they told her that it should be ducted bback into the system, they wont fail it because it still meets the required emissions level.
| | #6 | ||
| The Thrill of Driving.... | Re: TB breather pipes and oil breather on turbo car? On the turbo cars the two small vacuum pipes are not needed, you simply connect them to each other witha bit of silicone vacuum pipe. As for breather system, the cam cover breather should be linked round to the pipe which the air filter is connected to. You can put an oil catch tank in place if you wish in this somewhere, I and Emma both have catch tanks of slightly different design, but in roughly the same place. Mine is where battery used to be making it very easy to fit, Emma's is a square one which actually fits between the battery and strut brace bar, tho I can't find any pics of this. I wouldn't runa car with it venting to air as it smells and can leave oil residue on anything below it as remember turbo cars will have more crank case pressure than a N/A car.
__________________ ![]() 1992 Lancia integrale EVO1; 1995 Toyota Celica GT4 ST205; 2001 Seicento Abarth 1.4 16V 6speed (OK that one's Emma's) | ||
| | #7 | ||
| i am | Re: TB breather pipes and oil breather on turbo car? what you want is a nice pipercross filter with a take of for a crankcase breather feed. where would one get one? ![]() (at a reasonable price)
__________________ need to contact a mod? click me _need to contact admin? click me_FAQ's_ Guides_events_everyone join this ![]() Want +20BHP for £2? Last edited by custard; 13-11-2006 at 17:21. | ||
| | #8 | ||
| MG ZR Owner :) | Re: TB breather pipes and oil breather on turbo car? Pipercross but not a reasonable price
| | #9 | ||
| i am | Re: TB breather pipes and oil breather on turbo car? | ||
| | #10 | ||
| | #11 | ||
| i am | Re: TB breather pipes and oil breather on turbo car? hmmm has it been 15 minutes already? | ||
| | #12 | |||
| 16V Power!!! | Re: TB breather pipes and oil breather on turbo car?
Found my pic of the oil catch tank, quite a bit different to Aaron's. It sits in there quite nicely as i don't plan on moving the battery at this point in time. ![]() ![]() emz
__________________ Seicento Abarth 1368 16v conversion (1st in the UK) ![]() VAD Hi Boost Turbo Cinq- (SOLD 12/01/2008) | |||
| | #13 | ||
| The Thrill of Driving.... | Re: TB breather pipes and oil breather on turbo car? Since those pics were taken at the trial fit stage, the tank now sits square in the corner and not against the throttle body/accelerator cable before anyone says its fouling against stuff
| | #14 | |||
was going to get my filter modded with oil take off pipe but have you got any pics?cheers for the info peeps was thinking of putting some tube on the small vacumm pipes as when i put my fingers over them it didnt cut the engine out so ill do that at the weekend.
| Updated Cinq Turbo pics plus spec list... | J333EVO | Members Motors | 93 | 23-12-2006 00:01 |
| | al_scott | Marea | 6 | 03-06-2006 21:07 |
| Die Hard!!! | The Negotiator | Leisure Lounge | 27 | 24-04-2006 22:20 |
| Fiat X1/9 racing ??? | Squadracorse | X1/9 | 19 | 14-12-2005 16:22 |
