| lowering 60mm im getting my cento lowered 60mm and im wondering what is the biggest size wheel i can can on without modding the arches or at least not much modding? thanks
__________________ KeEp It HaRdCoRe ![]() Understeer is when you hit the wall with the front of the car. Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. | |||
| ' | Re: lowering 60mm Depends on the width of the wheel, tyres, offset. As a rough guess, I'd say 60mm is about 14" max, but thats just a feeling and not backed up. I recon at 14" on 60mm, you will still get scrubbing and rubbing. Hope your changinf the dampers as well for a drop that large. Kristian
__________________ Black Seicento Sporting mk2 1242cc 16V conversion finished and removed! ![]() Megasquirt installed, a constant evolution 1368cc and 6 speed running great now ![]() My Members Motors thread ![]() | ||
| | #3 | ||
| Scandinavian Passion.... | Re: lowering 60mm as I've found out today.. the Sei can take a rather tall tyre with very little rubbing on -30mm but that's on a skinny 175 wide tyre. If you go wider and you'll have more problems than I look to be having, though the Cinq arches help you I don't think they'll help that much. Edit wasn't thinking I'm on -30 not -60
__________________ Daily Driver: Seicento Sporting, Dark Grey, MPI 1108cc 8v, stock externals Track Day: Seicento Sporting, Yellow, High Boost 1247cc 8v, Factory Abarth body kit Luxury Liner: Volvo V70 D5 Sport, Black, chipped & uprated intercooler, V70R body kit Last edited by StoneNewt; 12-11-2006 at 00:21. | ||
| | #4 | ||
| custodian of imola blue | Re: lowering 60mm Is this a standard Cinq or a Sporting? Personally I think that 60mm is too much on a standard, way, way too much on a Sporting. The result will be something that's impractical on anything short of a racetrack. Even 14" wheels (depending on tyre fitment, etc.) can be a bit of a pain on standard cars lowered 40mm. Go to 15" and you're very likely to encounter problems. And it sounds like you're paying someone to do the work........
| | #5 | ||
| MG ZR Owner :) | Re: lowering 60mm He has an SX
| | #6 | ||
| Re: lowering 60mm Mines also an sx its been lowered 60mm and has 15's with 195/45 tyres. Ive got a small amount of scrubbing on the front arches (had no work done) and the backs are fine untill there is someone in the back but again its little scrubbing.
__________________ Blue Cinquecento 1242 15" Alloys, Lowered 60mm, 40mm Tb, McKcrich chip, Custom Door Builds Yellow Cinquecento turbo | |||
| | #7 | ||
| custodian of imola blue | Re: lowering 60mm The SX doesn't have an anti-roll bar, does it? That would be the very first thing I'd fit.
| | #9 | ||
| i have the non sporting 900cc cento. i will be buying a strut brace for it upper and lower if i can afford it. and yes im getting it done by a garage and i will be keeping the standand dampers. im curious how much are dampers that would suit my cento and its 60 mm drop. thanks
| | #10 | ||
| TruBlu | Re: lowering 60mm It'll be cheaper to get your shocks and springs together as part of a kit, so that they are matched. 60mm drop kit would included shortned shocks. You can fit the 60mm springs without but your gonna seriously reduced the lifespan of the standard shocks. As regard to strut braces, you need to get down the scrappies and take the anti-roll bar off a sporting, then get a aftermarket jobby for the top (don't put it on until the suspension is on, it'll just cause more understeer if you do) Can't give you prices tbh, they vary widely from shop to shop and manufacturer to manufacturer, have a shop around is the best advice i can give there
__________________ ![]() | ||
| | #11 | ||
| The element of suprise! | Re: lowering 60mm I've seen uprated gas shocks for aroun 160 a set, you're probably better off getting the springs and shocks together in a set as mentioned above, I'm on a -50mm drop by the way
| | #12 | ||
| this is where i stand | Re: lowering 60mm 60mm drop for a sporting, or an s / sx? 60mm drop for a sporting is 80mm drop for an s / sx? also, you need an anti roll bar - not a lower or upper strut brace. though an upper brace would be nice, lower not.
__________________ | ||
| | #13 | ||
| custodian of imola blue | Re: lowering 60mm Yep, anti roll bar. Like the man says, strut braces are nice (or at least, the top ones are -- you really can't use the bottom one except on a track). The ARB actually restricts the amount of roll and tends to cut out much of the understeer you get in the non Fire Cinqs and Seis. My own view is that any Cinq or Sei will benefit. They were a factory fitment on all Fire Seis, so suspension height isn't a real consideration when fitting them. The strut brace simply keeps the struts more in alignement when subject to extreme cornering loads (but by the time you get there in a 900 without ARB you'll be well through that hedge!). The Fire Sei and Cinq sporting ones are identical. Get one from a scrappy, but drench all the nuts and bolts in WD40 the day before you take it off and get all the bolts and brackets.
| | #14 | ||
| Scandinavian Passion.... | Re: lowering 60mm SPI Sei & Cinq ones are the same, MPI Sei has its own which should fit without moving anything on the car.
__________________ Daily Driver: Seicento Sporting, Dark Grey, MPI 1108cc 8v, stock externals Track Day: Seicento Sporting, Yellow, High Boost 1247cc 8v, Factory Abarth body kit Luxury Liner: Volvo V70 D5 Sport, Black, chipped & uprated intercooler, V70R body kit | ||
| | #15 | ||
| Re: lowering 60mm thanks for all the ideas and how to do's, next stop scrappy... thanks
| | puntoadam | Punto | 3 | 18-08-2006 16:07 |
| | paulbfd | Cinquecento / Seicento | 1 | 03-06-2005 14:03 |
| | SPUD | Cinquecento / Seicento | 19 | 21-04-2003 21:09 |
