The FIAT Forum
Old 29-10-2006   #1
cheekycento21's Avatar
Trader Rating: (0)
cheekycento21 has donated! United Kingdom
Exclamation White smoke and a misfire!!!!!
Hi i have a p reg cinq. was driving to work and suddenly saw loads of white smoke out the back and it started to miss again. it missed before on number 2 but took plug out and saw was coated in oil. cleaned and put back ran great. headgasket or maybe something more fatal??? may take off head to look. please help!!!!!!!!!!!!!
cheekycento21 is offline
Old 29-10-2006   #2
MG ZR Owner :)
SkinzCinqSporting's Avatar
Trader Rating: (2)
SkinzCinqSporting has donated!
Re: White smoke and a misfire!!!!!
White smoke sounds like a possible headgasket failure.
SkinzCinqSporting is offline
Old 29-10-2006   #3
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
white smoke probably steam and, if the engine has warmed up the only likely cause is head gasket failure. a compression test will reveal all.
fingers99 is offline
Old 29-10-2006   #4
Scandinavian Passion....
StoneNewt's Avatar
Trader Rating: (0)
StoneNewt has donated! United Kingdom
oil and water in the cylinder? sounds like an HG.. pressure test time
Daily Driver: Seicento Sporting, Dark Grey, MPI 1108cc 8v, stock externals
Track Day: Seicento Sporting, Yellow, High Boost 1247cc 8v, Factory Abarth body kit
Luxury Liner: Volvo V70 D5 Sport, Black, chipped & uprated intercooler, V70R body kit
StoneNewt is offline
Old 29-10-2006   #5
Trader Rating: (0)
Exclamation Re: White smoke and a misfire!!!!!
lots of oil every where but think thats cam gasket. if i take the head off you reckon that may show the problem? wot kind of job is it? cam belt?
Old 29-10-2006   #6
Trader Rating: (0)
have had compression tested and they said had no compression on no2. maybe dropped a valve?
Old 29-10-2006   #7
Trader Rating: (0)
sounds like a valve to me too,if u take the rocker cover off and check the valve springs u will probley see one poped off if the pistons hit it hard and broke the valve off and u would hear it rattling in the chamber, but if u kept driving it will be inbedded into the top off the piston,the oily plug u had was probley the valve bent but steel in place,wip the head off, if the scoring isnt to bad ie not deep just give it a bit of a rub down to take the rough off replace the valve and give it a try, ive done these before and the car still going strong and it happened 2 years go
the gentleman is offline
Old 04-11-2006   #8
Trader Rating: (0)
Have taken the head off. Pistons look fine, head and valves all look fine.
Running out of ideas. Any one got any ideas???
Old 04-11-2006   #9
Trader Rating: (0)
What about the gasket? Look for holes around the burn ring on no 2 cylinder.
AIRBAGS SAVE LIVES, WHAT WOULD YOUR FAMILY DO WITHOUT YOU? GET THEM FIXED.
NumanR is offline
Old 05-11-2006   #10
Trader Rating: (0)
The gasket looks ok its not broken any where.
There doesn't seem to be anything that stands out to be wrong.
Old 05-11-2006   #11
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
You'll need to get the head pressure checked and skimmed.
D
rallycinq is offline
Old 11-11-2006   #12
Trader Rating: (0)
Angry Re: White smoke and a misfire!!!!!
The head has now been skimmed and crack tested, all ok. Its had new spark plugs. The HT leads are fine and the the oil valve stem seals are ok.
Head is now back on. Engine runs but there is still a mis fire and oil is still being burnt. But I dont have any idea what it could be.
Please help?????
Old 11-11-2006   #13
rallycinq's Avatar
Trader Rating: (1)
Back to basics. With the engine running using insulated pliers remove one plug lead at a time, replacing it before removing the next one.
You should get one where the removal of the lead makes no difference to the misfire. That should be the cylinder with the problem.
Compression test, and, if as suspected is low, add oil. If the compression comes up, it will be rings or bores.
D
Old 12-11-2006   #14
Trader Rating: (0)
Have checked for spark. all there, but on no3 no spark out of end of lead. when tryed to see if had spark, saw spark out of coil end!! what does this mean?? then did copression test and found practically no compression on no2,the other 3 had v high pressure. as had head skimmed and crack tested, and valves cleaned and reground could this mean bottom end dead?? am gettin v stressed and frustrated. help!!!
Old 12-11-2006   #15
Fehler in alle Teilen
Fivehundred's Avatar
Trader Rating: (0)
Fivehundred has donated! United Kingdom
Do what rallycinq suggested, compression test each cylinder dry, if one is low put a bit of oil down the bore.
If the rings are toast the oil will temporarily up the compression as it stops leakage past the piston. Throttle wide open whilst you test wil give you the most consistent result. There should be no more than a 10% variation between the cylinders.
Fivehundred is offline
(T) brava td 100 white smoke shuggy Bravo / Brava 10 24-10-2006 21:54
(T) brava td 100 white smoke shuggy Bravo / Brava 0 19-10-2006 13:04
(T) White smoke sorted...Yeah! ashleyjewitt@fsmail.net Cinquecento / Seicento 4 21-02-2006 20:44
(T) White smoke still after spending £300! ashleyjewitt@fsmail.net Cinquecento / Seicento 20 06-02-2006 19:31
(G) White Smoke Drinu Uno 7 24-11-2004 15:54
