The FIAT Forum
Old 12-11-2006   #16
cheekycento21's Avatar
Trader Rating: (0)
cheekycento21 has donated! United Kingdom
Exclamation Re: White smoke and a misfire!!!!!
ok cool then that should show the fault? why was the no3 plug lead sparking at the coil end??
cheekycento21 is offline
Old 12-11-2006   #17
Fehler in alle Teilen
Fivehundred's Avatar
Trader Rating: (0)
Fivehundred has donated! United Kingdom
Yes it should. An engine needs 3 basics to work, fuel, compression and ignition. Obviously if your ignition is sparking someplace other than the sparkplug your engine won't run properly, it sounds like you have a failed ignition lead.
I reality though all that will cause a misfire, not clouds of smoke or low compression. Diagnose the bottom end, only once you're sure that is serviceable is it meaningfull to deal with the ignition issue.
Fivehundred is offline
Old 12-11-2006   #18
Trader Rating: (0)
swopped over plug lead and still sparked at the coil. nackerd coil? its starting to look like its going to need a new engine. dont wana strip head again. so if i put oil dwn the bore, and retest it do i fill it up then put tester in? flaming car!! why cant it be easly to sort out. wish it was something obviuos like a broken valve/piston.
Old 12-11-2006   #19
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
You only need to put a little oil in, say something like a dessert spoon full. It need to coat the top of the piston and the rings to temporarily seal the piston. This won't last for long, but if the compression rises, then falls again it definately the rings or bores.
If the compression does not change then its the head, but you know thats alright.
If the spark is still happening at the coil, even with the complete lead swapped, then the coil has split. You will not get any spark at the plug because the spark will take the shortest route.
You can replace the coils individually, so you only need one, although changing one often causes the other to go.
D
rallycinq is offline
Old 12-11-2006   #20
Trader Rating: (0)
Arrow Re: White smoke and a misfire!!!!!
do they? ok thanks mate you have been v v helpful. hope aint been to annoying? will try wot u say some time this week. thanks again. will let you no how it go.
Old 12-11-2006   #21
rallycinq's Avatar
Trader Rating: (1)
No, probs. If I didn't want to help, I wouldn't log on.
D
(T) brava td 100 white smoke shuggy Bravo / Brava 10 24-10-2006 21:54
(T) brava td 100 white smoke shuggy Bravo / Brava 0 19-10-2006 13:04
(T) White smoke sorted...Yeah! ashleyjewitt@fsmail.net Cinquecento / Seicento 4 21-02-2006 20:44
(T) White smoke still after spending £300! ashleyjewitt@fsmail.net Cinquecento / Seicento 20 06-02-2006 19:31
(G) White Smoke Drinu Uno 7 24-11-2004 15:54
