The FIAT Forum
Old 04-03-2004   #1
Trader Rating: (0)
Strut Brace
Hey
Does a strut brace improve the handling of ur car? How easy are these to fit? I've seen one on ebay for a reasonable price http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=2463431676&category=40 192 do they jus bolt on or is it more difficult than this? Also if one is fitted to the front does a rear one need to be fitted?
Cheers Mike
"Yellow is Mellow"
96P Cinq Broom Yellow Full Abarth Kit K&N 57i Clifford Alarm Lowered Tinted and a Recent badger shape dent in the front :(
Mikey_B is offline
Old 04-03-2004   #2
Banned
Trader Rating: (2)
Bushboy has donated!
never found any for the rear of a cinq. I was wondering this also. They did them for the rear of the uno but then again maybe the suspention in the rear of a cinq is completly differnet and doesnt need one.
Bushboy is offline
Old 04-03-2004   #3
i am
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
i wouldn't worry about a rear one for a front wheel drive car,they do help the handliing a bit but you want an anti roll bar and decent shock set up for handling but there easy to fit and look good.that guys been selling a few lately
The Fiat Cinquecento
Fun While It Runs
custard is offline
Old 04-03-2004   #4
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
A rear one makes the car handle completely differently, quite tail happy, which can be fun, in the right circumstances.
D
Grumpy old git going fast downhill rather than downhill fast!!
rallycinq is offline
Old 04-03-2004   #5
Cento Boy
surfin_fella's Avatar
Trader Rating: (0)
surfin_fella has donated! Australia
I got that exact strut brace. Bit of a bitch to fit. spare a few hours! but worth it. Steering seems more responsive and not as much roll
Sie
Black 96P Cinq Sporting
OMP Strut Brace, GSR F1i Induction, Pioneer ICE
surfin_fella is offline
Old 06-03-2004   #6
Trader Rating: (0)
why it take u a while to fit? U have to manipulate it?
Was this guy selling it genuine?
Cheers mike
"Yellow is Mellow"
Mikey_B is offline
Old 06-03-2004   #7
rallycinq's Avatar
Trader Rating: (1)
To fit most front upper strut braces requires release of the things already bolted on to the strut tops, fitting of the brace, then some repositioning or remodelling of brackets to get all the other stuff back into place.
D
Old 07-03-2004   #8
max
max's Avatar
Trader Rating: (0)
Just fitted exactly the same brace to my Cinq. It took 20 mins! To fit it undo the 3 13mm nuts holding each strut, move the header tank out the way from the drivers side,and move the ecu out the way from the passenger side (dont forget to undo the akward 10mm nut on the lower part of the ecu mount), also slide the battery back as far as it will go. Fit it directly on top of the struts/body and bolt everything back on top. Its tight round the battery but the only part you need to modify will be the fuse cover on the ecu mounting. 2mins cutting with a hacksaw, nothing to worry about!:D
Cinquecento............Its not the size its how you use it!
max is offline
Old 07-03-2004   #9
fixitagaintomorrow's Avatar
Trader Rating: (0)
fixitagaintomorrow has donated! United Kingdom
wow - they have changed the design then.
Pete.
1242cc cinq,turbo cinq,Cinqs&Seis Yahoo group,Clubcento
fixitagaintomorrow is offline
Old 07-03-2004   #10
Cento Boy
Trader Rating: (0)
hmm, why didn't i think of thatB)
Sie
Old 07-03-2004   #11
polecat's Avatar
Trader Rating: (0)
polecat has donated! United Kingdom
Just a quick question. If you have to loosen/remove the strut bolts to fit the brace...
...does that mean you should get the camber set up again?
<h5><font color="black">Dave. :)
Marea HLX 2.0 20v
</h5><h6>Airbox with attitude[8D] Now only getting 21.4mpg
Blue Momo Tomahawk Gear Knob, Momo Alu H/brake, Blue stuff ;)
Ecotek fitted, removed and waiting for warm weather.
So much to do, so little time.... and Totally Skint!! :(</h6></font id="black">
polecat is offline
Old 07-03-2004   #12
Trader Rating: (0)
I can only speak for the cinq, but there's very little movement in them so I wouldn't have thought so.
Pete.
Old 09-03-2004   #13
max
max's Avatar
Trader Rating: (0)
The struts have fixed mounting points, so the camber cant be adjusted from standard. The only way to change the camber would be to either get offset top mounts or adjustable lower arms, either way its expensive & a waste of time.... At the end of the day its a Fiat not a Mclaren!
max is offline
Old 09-03-2004   #14
rallycinq's Avatar
Trader Rating: (1)
Eh... No. I have offset top mounts on my silver one and they weren't much more spensive than standard ones.
cheers
D
(G) Strut Brace beastyjay Cinquecento / Seicento 15 17-07-2004 01:23
(T) Front lower strut brace for seicento tearer Cinquecento / Seicento 2 20-04-2004 18:01
(T) Strut brace fitting Jonna83 Cinquecento / Seicento 7 31-12-2003 20:27
(T) Cinq strut brace mickymunch Cinquecento / Seicento 6 09-06-2003 21:01
