The FIAT Forum
Old 20-10-2006   #1
woj
woj's Avatar
Trader Rating: (0)
Netherlands
The right engine mount
Hi folks,
I just replaced two engine mounts: the rear one and the one on the left (gearbox side that is). The right one (alternator side) also needs replacing (badly ) and this is the one I am most scared of, mostly because access seems to be really poor:
1. How difficult it is compared to the other ones (which were piece of cake I would say)
2. Anything particular I should watch out for in terms of snapped bolts, right sequence of things etc. (a mini howto would be nice, the procedure is in Haynes, but there it says the engine was out and I want to do it in situ). I understand that for better access the wheel and wheel arch go out first. Anything else I can remove without too much of a hassle that would help to do the job?
3. Any good ideas on how to spray the bolts and nuts on this mount with WD40 without spraying all over the alt. belt and without taking it off?
Cheers,
Woj
woj is offline
Old 20-10-2006   #2
i am
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: The right engine mount
no big hassle with the drivers side as to remove the alternator it needs undone.easy job.
wheel liner out and support the engine on a trolley jack so you can lower it gradually
custard is offline
Old 20-10-2006   #3
woj
woj's Avatar
Trader Rating: (0)
Netherlands
Alternator out it is then? Any second opinions on this, cause I really don't feel like twidling with the alternator... /Woj
EDIT: Now I got you mate, mount needs undoing whenever the alternator needs to go out, not the other way round...
woj is offline
Old 20-10-2006   #4
i am
custard's Avatar
Trader Rating: (1)
no the alternator isnt touched,just if your doing the alternator its the same as the mount is dropped.
its a very simple job
custard is offline
Old 20-10-2006   #5
woj
woj's Avatar
Trader Rating: (0)
Netherlands
Yeah, right, see my edit above... Thx /Woj
woj is offline
Old 21-10-2006   #6
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
It's probably not a great idea to get lots of WD onthe alternator belt. You could either use the plastic straw which comes with the canof WD40 or just spray some in a jar and put it on with a paintbrush or a stick.
fingers99 is offline
Old 21-10-2006   #7
arc
this is where i stand
arc's Avatar
Trader Rating: (0)
arc has donated! United Kingdom
why are using WD40 anyway.. you want a pentrating oil on there, not a water displacement!
arc is offline
Old 21-10-2006   #8
woj
woj's Avatar
Trader Rating: (0)
Netherlands
Well, WD40 works fine for me as a deruster so far. And penetrating oil is also greasy - same problem /Woj
woj is offline
(T) Uno 1.0 ie. Smelly smoke and knocking noise. SilentPartner Uno 17 27-03-2006 17:00
(G) passenger engine mount 99sei Cinquecento / Seicento 2 06-03-2006 23:02
Engine & Bay Cleaning crash Car Care 6 07-08-2005 13:02
