FIAT Auto Specialist Team
Old 12-10-2006   #1
Dutch Sniper Champion, Let it Ride Champion
cento back brakes sticking,
sitting outside in my car today i put hand brake down, took it out of gear and tried to push it. To my astonishment the little car didn't budge, i looked at my scrawny legs and realised it wasn't them that was at fault.
i got out and tried pushing from the back. but with no avail, i then started her up and tried to pull off real slow, and there was some resistance as if somthing was holding me back, although there wasnt a sound i could tell it was from the back brake. i havent driven her for about a week and now i find the brake is sticking a little. does anyone have any help for me as im new to this place and highly appriciate all your help thanks alot guys
Rikki
seicentaff is offline Reply With Quote Quote
Old 12-10-2006   #2
MG ZR Owner :)
SkinzCinqSporting's Avatar
Trader Rating: 2
SkinzCinqSporting has donated!
Re: cento back brakes sticking,
The handbrake arms have probably seized, look at top of technical in the FAQs and all you need to know is there
Welcome to the forum
SkinzCinqSporting is offline Reply With Quote Quote
Old 12-10-2006   #3
MG ZR Owner :)
Trader Rating: 2
Sod it, seeing as you are new, here you go
http://www.fiatforum.com/cinq-sei-te...andbrakes.html
Old 12-10-2006   #4
Trader Rating: 5
fingers99 has donated!
I can see 4 possibilities:
1. The drums and brakes have got very wet and partially seized together. Driving the car (relatively) slowly and left foot braking should remove that in no time.
2. The handbrake cable (unlikely) or the actuating elbows (likely) have seized on. You'll likely be able to tell by looking at how the spring at the hub end of the cable reacts to handbrake on and off. You may be able to push the brake off by pushing against the elbow with a srewdriver of whopping the screwdriver with a mallet. (Brakes off, spring extended). If this is the case, strip out until you can remove the pivot elbow, dunk it in WD40 and work it until it becomes really sloppy then wipe off the WD40 and work coppaslip into the pivot.
3. The springs inside the hub -- the brake springs -- have become weak. Replace. Use a flat head screwdriver with a V cut in it. Be careful: they are very strong.
4. The slave cylinders have developed a fault. Replace as a pair.
Of the lot, 2 is the most likely IMHO.
Good luck!
fingers99 is online now Reply With Quote Quote
Old 13-10-2006   #5
Moderator
blu73's Avatar
Trader Rating: 1
blu73 has donated!
Snowboard Slalom Champion
Agree with fingers, most likely to be hes nimber 2. But i'd say just pop down fiat and buy a new set of elbows, cost bout £8 iirc
Black Betty - Cinq 1242 8v * Marella Agnelli - Seicento Turbo * Molly II - mk1 Punto GT3 * Urchin - Alfa 159 SW TI 1.9jtdm
Quote Originally Posted by Ouby View Post
Getting a little off-topic talking about blu & his massive girth....
blu73 is offline Reply With Quote Quote
Old 13-10-2006   #6
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Having stripped the rear brakes on Garyaird's car this week, it had the full set.
1) Handbrake cable seized
2) Wheel cylinders seized
3) Levers seized
Oh, And the pipes all corroded.
HOUSE
D
rallycinq is online now Reply With Quote Quote
Old 13-10-2006   #7
thanks for that guys im new to the motoring world my dad baught it as a 18th bday prezzie, im chuffed with the car.
i have been out a few times and it was fine, i came back from hols and it looks like they have partially locked.
can anyone else help me? you know the millage thingy the bottom one. i tried resetting that the other day using the right hand button, all the numbers have gone half way and it isnt going back to 00000 can anybody help? its stuck,
hehe hail the sento drivers
Old 13-10-2006   #8
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Quote Originally Posted by seicentaff
Press it again and again. It should trigger eventually.
D
Old 13-10-2006   #9
Trader Rating: 1
Quote Originally Posted by rallycinq
D
But if it doesnt after another 50 goes just give up, theres a small connection in the back which has popped out of place and will stop the trip counter resetting, mines not worked for ages, it doesnt affect the odometer at all though, You can get in to fix it but to me it sounded like way too much hassle.
Kev
SeicentoKev is offline Reply With Quote Quote
Old 13-10-2006   #10
aww sh!te i really wanted that to work
never mind i guess i have to live with it
Old 13-10-2006   #11
Trader Rating: 5
3) Levers seized
HOUSE
D
By the time it's finished that car will be new!
Old 15-10-2006   #12
I can beat that. On the "family" Cinquecento currently SORN awaiting my son passing his test:
1 Both rear brake back plates corroded right through
2 Both handbrake levers seized
3 Hand brake cable dodgy
4 Brake shoes replaced as would be false economy not to do so after all the other work
Good job I did it all myself as parts alone around £200 on a car not worth more than £400 at best. Still, it is more a family heirloom than a car so has to be preserved.
doctorchris is offline Reply With Quote Quote
Old 15-10-2006   #13
now with added gold
custard's Avatar
Trader Rating: 1
custard has donated!
£200 for those parts?
Old 16-10-2006   #14
doctorchris,
you cant beat me lol me and rallycinq have had to (and still are) replace 1x caliper,2 sezied wheel cylinders,a whole new set of shoes,a handbrake cable,2 sezied pivot arms,2 seized drums,and 2 corroded and snapped brake pipes,and a whole new shoe fitting kit,
cant beat that
all that cost me £150ish for parts,
but then again my car is a bit of a nightmare i may aswell rip everything out and start from the ground up coz so far ive done:
Lowered £67,new sportex backbox £115,new interior £100,new alloys £130,painted dash £20,new aerial £5,new alternator to get fitted £5,changed all the door locks free ,fixed the brake lights,free
still to do:
replace windscreen £45,replace centre section of exhaust £35,trace a slight oil leak,fit new bulbs,touch up the paint work,get new bonnet £70 ,fix front bumper and mesh it,
ive spent about £600 so far on parts
garyaird11 is offline Reply With Quote Quote
Old 16-10-2006   #15
I Need Beer
allanhelen's Avatar
allanhelen has donated!
you should have mailed for me I have an oval Sportex back box in my garage only done about 4K miles you could have had it for half what you paid new
No FIAT's any more and nothing else sensible either
allanhelen is offline Reply With Quote Quote
(G) Sticking front brakes Tony M Panda (Classic) 3 13-08-2006 16:42
(T) Brakes failure Dean062 Multipla 10 10-08-2006 11:26
Die Hard!!! The Negotiator Leisure Lounge 27 24-04-2006 21:20
(T) Rear brake back plate... bravabob Cinquecento / Seicento 7 17-07-2005 23:02
(T) engine swaps HP Cinquecento / Seicento 0 31-12-2004 00:17
