General Buying a Cinq
peaster2k
Established member
Washington, United Kingdo
Hi people
I am looking for a bit of advice from people, I am really thinking about buying a cinq in the next couple of weeks (i hope) depending on if i can get the £ together. I was wondering if anyone can give me some pointers on what to look out for, common problems, things that might cost a bomb to put right a few months down the line. It will be a cinq sporting that i am buying(only way to go[8D]). I have found a few on autotrader near me, like the grey one :D
http://atsearch.autotrader.co.uk/WWW/cars_search.asp?modelexact=1&lid=search_used_cars_full&make=FIAT&model=CINQUECENTO&variant=&keywords=sporting&min_pr=75&max_pr=&mileage=&agerange=&postcode=ne37+1ra&miles=40&max_records=50&source=0&photo=1&sort=3&ukcarsearch_full=SEARCH
I know that i should not buy it without the red key as this is not good. Also i know there is a 54,000 mile service that has to be done (as DJ_bucho has told me), is there anymore in the life of a cinq that must be done, etc. As the one I’m looking at has 28,000 miles on the clock (for N reg I think that’s canny good).
I am a 21 year old student in my last year at Uni as this will be my first car and I know insurance will to be VERY expensive [V]. Even though I have had my license for 3 years nearly, as it will be my first policy has anyone got any recommendations about good CHEAP companies to go with. As does anyone know any good garages around the North East that could possibly fix any problems that might happen. Just thinking ahead, as knowing my luck something will u tits up.
David Pearson
wh ycant u buy without the red key?
"Yellow is Mellow"
96P Cinq Broom Yellow Full Abarth Kit K&N 57i Clifford Alarm Lowered Tinted and a Recent badger shape dent in the front :(
if you dont have the red key then you cant get any more keys cut This is because the Red key stores a special code that deactivates the imobiliser. this is copied onto the blue keys but cannot be copied onto another key using just the blue key (or atleast thats what ive been led to believe). if you loose your red key and then your blue keys then your buggered and will have to buy a whole new locking system which can be very expencive!
Cinq Sporting
1.1L engine
K&N 57i kit
Sparkrite alarm system
Meshed front bumper
Ripspeed pedals
because without the red key you cannot reset the ECU if it looses power
insurance, give HIC a ring on 08451-290-290
check the stickys in technical for problems
if you wait till everyone is back from the meet, someone should be able to give you a better idea of what to look out for :)
Cinq Sporting - and yes, its broom yellow!
I got a key cut from my blue key and that worked? Deactivated my immobiliser?
"Yellow is Mellow"
Yeah thats what the red key is for. Never the less if the car did not have one then i would wonder why it has not got it in the first place. As something could have gone wrong with the car before hand.
Had you changed the battery or something, or did you just get anohter key cut and try that?
David Pearson
the red key is used for technical diagnostics and to reset your ecu in case of a breakdown etc...
You can get more keys cut without the red key, timposons do it for about £20
Always good to have the red key, but i wouldn't be too fussed if it didn't have it with an n-reg car, just use the fact that it hasn't got it to bargain down the price with whoever your buying it from
hope this is of some help
when i first bout car red key was supposidly lost but i said if they found it id sort em 20!
before that though the fiat garage said there branch in southend could use the blue key to create copies by removing the info! i think it can be done now although it never used to be available and limited branches use the machines.
whos ur daddy!???
Good idea about getting the price down i like that. Cheap the price. I know there was some models that did not have the red key, but i am not sure of which ones. I reckon, at a guess, models after 96 had a red key and the ones before did not. Not a 100% on this, someone will have to confirm this for me.
David Pearson
i've got an N reg cinq WITH a red key so haggle away,paid a grand for mine at a garage 2 former owners 55000 miles and small dents on the bonnet where the former keeper tried to push the bonnet shut,theres plenty out there so if you're not happy walk away i needed a car fast so was pushed for time
Custard boy the man who loves the man from Creative
try norwich union, very good rates for me at least
btw, saw that cinqi, dont reckon cinqs look good in silver tho tbh (personal opinion/taste, no offence intended)
Now written off Cinquecento Sporting,
and yes it was indeed Broom Yellow :(
Dont worry, the poppy coral lives on for another car :p
hey
What do you mean you have seen? Have been to view the car? If so was there any problems with it, etc? What did you not like about it, i only have the pic to go off. I am not too bothered about the colour, don't mind the sliver one bit.
David Pearson
Couple of things, as your 21, had a licence 3 years, you wont find it THAT expensive, although buying a tin of beans is hard for you uni lot ;) As for the red/blue key thing, i had only 1 blue key when i brought the car, so just got it cut for £25, and use that for day to day use. Having no red key has never been an issue for me.
Also 21,000 miles sounds almost too low. Probably genuine, but perhaps get a car check/HPI check done just to be safe. £40 could end up saving you £££.
And make sure you get a Haynes manual! This will be your bible throught Cinq ownership.
Cinq Sporting 1997 https://www.fiatforum.com/forum/topic.asp?TOPIC_ID=8033 Parts Needed!
it says 28,000 :) Do you know where i can get a good HPI check done then? Or does someone have to come out and look at the car?
Yeah good idea about the manual, Brian told me this is a must.
David Pearson
the garage did a HPI check on my car when I bought it. you buying it private?
Sie
Black 96P Cinq Sporting
OMP Strut Brace, GSR F1i Induction, Pioneer ICE
