The FIAT Forum
Old 10-10-2006   #1
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
ECU resetting
Today we have a different slant on the subject of ECU resetting.
My car has an FIA cut out switch. This takes all the power away from the car every time it is switched off.
Will this reset the ECU every time, I think it will, so whats the answer.
D
rallycinq is offline
Old 10-10-2006   #2
I Need Beer
allanhelen's Avatar
Trader Rating: (0)
allanhelen has donated! United Kingdom
Re: ECU resetting
Seperate live feed to the ECU? or would that be against regs?
you could use a seperate small 12v battery and have it wired via a relay you know like a UPS for a PC
VAD Hi Boost Turbo Cinq
None Fiats 3.2 V6 Cavalier, Peugeot 206 GTI 180 & JR Supercharged Mk2 Mazda MX5 1.8
allanhelen is online now
Old 10-10-2006   #3
rallycinq's Avatar
Trader Rating: (1)
Re: ECU resetting
That was my first thought, but strictly against the regs.
That sounds feasable, I think I'll have a look at how electric extinguishers are fired with the ignition cut.
D
Old 10-10-2006   #4
I Need Beer
allanhelen's Avatar
Trader Rating: (0)
Re: ECU resetting
D.
Just had another thought what about a storage capacitor in the live feed for the ECU not sure how long it would power it for but could be a quick easy solution.
you might be able to hide it in the ECU case so no one would ever know
Old 10-10-2006   #5
rallycinq's Avatar
Trader Rating: (1)
Re: ECU resetting
D.
another cunning plan, thanks
D
Old 22-10-2006   #6
Diwiak's Avatar
Trader Rating: (0)
Slovakia
Re: ECU resetting
So disconnecting battery resets ECU?????? (on cinq 1.1??)
Diwiak is offline
Old 22-10-2006   #7
Scandinavian Passion....
StoneNewt's Avatar
Trader Rating: (0)
StoneNewt has donated! United Kingdom
Re: ECU resetting
after a period of battery disconnection the ECU will reset
Daily Driver: Seicento Sporting, Dark Grey, MPI 1108cc 8v, stock externals
Track Day: Seicento Sporting, Yellow, High Boost 1247cc 8v, Factory Abarth body kit
Luxury Liner: Volvo V70 D5 Sport, Black, chipped & uprated intercooler, V70R body kit
StoneNewt is offline
Old 23-10-2006   #8
nitrane.co.uk's Avatar
Trader Rating: (0)
nitrane.co.uk has donated! United Kingdom
Re: ECU resetting
'period' being what? Seconds, minutes or hours? I'm in the same boat as rallycinq so i'd be interested in the answer.
John
BIG Fiat... now on Facebook
nitrane.co.uk is offline
Old 23-10-2006   #9
StoneNewt's Avatar
Trader Rating: (0)
Re: ECU resetting
Guessing I'd say it's in the region of an hour, I can't do a 3h charge of the battery w/out the ECU resetting
Old 23-10-2006   #10
Trader Rating: (0)
Re: ECU resetting
OK, so there's no problem leaving the master switch on, apart from the time when the scrutineer test whether it works
John
Old 23-10-2006   #11
I Need Beer
allanhelen's Avatar
Trader Rating: (0)
Re: ECU resetting
I thought it was in the region of 30 second although I think it may be longer on the MPI sei's
Old 23-10-2006   #12
StoneNewt's Avatar
Trader Rating: (0)
Re: ECU resetting
Both the punto and Sei seem to take forever to take at least 45min (punto took less time) before I got a noticeable difference in fuel consumption... that's the only indication I've got of a reset ECU
Old 23-10-2006   #13
Diwiak's Avatar
Trader Rating: (0)
Slovakia
Re: ECU resetting
??? reseting ECU decreasing consumption???
Diwiak is offline
Old 23-10-2006   #14
StoneNewt's Avatar
Trader Rating: (0)
Re: ECU resetting
After resetting the ECU it then has to work out the exact 'landscape' it's in. Until it has an exact map for the 'landscape' it will use less than optimal fuelling.
Old 23-10-2006   #15
I Need Beer
allanhelen's Avatar
Trader Rating: (0)
Re: ECU resetting
When i disconnect the battery with the Mckrich chip you can tell straight away if the ECU has reset as the performance drops quite significantly. I basically diconnected the battery turned it round and reconnected it and you could tell the ECU had reset
(T) Resetting Ecu - Help Frank_1 Punto 1 23-09-2006 18:12
(T) Resetting ECU ippikin Punto 11 18-09-2006 18:20
(T) Resetting the ECU on my Chinq northernmonkey Cinquecento / Seicento 8 13-02-2006 12:19
(T) resetting ECU & headligh bulb replacement (mk1) beau Punto 19 20-01-2006 12:02
(T) Resetting ECU OJ Cinquecento / Seicento 4 21-04-2004 00:14
