| Rear springs - which direction? Hi there, Quick question - I just got my self a new set of OMP springs to be mounted shortly. I noticed that the rear springs I have in the car right now have all the coils evenly spaced (or so it seems). The new springs have 5 coils very close to each other and then 5 coils spaced out a bit more (normally I would say). So which side is up/down then? Cheers, Woj
| MG ZR Owner :) | Re: Rear springs - which direction? I'm no expert but I would Imagine the 5 coils closest to each other go at the top so there is less movement at the top of the travel, I tried finding fitting instructions on OMP's website but there were none.
| | #3 | ||
| Scandinavian Passion.... | Re: Rear springs - which direction? I doubt the way up will effect the springs response, you don't remove all movment from the 1st inch then 2nd etc the spring responds as a whole. Typically you'll put the tightly wound coils at the top.
__________________ Daily Driver: Seicento Sporting, Dark Grey, MPI 1108cc 8v, stock externals Track Day: Seicento Sporting, Yellow, High Boost 1247cc 8v, Factory Abarth body kit Luxury Liner: Volvo V70 D5 Sport, Black, chipped & uprated intercooler, V70R body kit | ||
| | #4 | ||
| ' | Re: Rear springs - which direction? Yep, makes no difference at all physically which way round they go.....i put the tight coils at the top so they trap less crap from the road, but other than that theres no right or wrong. Kristian
__________________ Black Seicento Sporting mk2 1242cc 16V conversion finished and removed! ![]() Megasquirt installed, a constant evolution 1368cc and 6 speed running great now ![]() My Members Motors thread ![]() | ||
| | #5 | ||
| custodian of imola blue | Re: Rear springs - which direction? Functionally, I don't think it makes any difference. But if you put the close wound coils at the bottom they'll fill up with damp crud and possibly rot the trailing arms out in no short time.
| | 1986Uno45S | Punto | 11 | 03-08-2006 01:12 |
| | GhostWKD | Cinquecento / Seicento | 21 | 28-04-2005 19:29 |
| | Body Stylist | Punto | 30 | 09-04-2005 17:02 |
| | chrisunoman | Uno | 14 | 18-02-2005 21:48 |
