Technical Problem with my car radio
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Zaziffic
France.
I've just bought a new CD car radio and i wanted to plug it to my Cinquecento but i've got a problem: it doesn't work. With my voltmeter, I can see that I've got +12V but when I plug my car radio, it disappears. It must be a ground problem because I verified all my fuses and they are not out of order. I haven't got the electric map of my car to check all wires so if someone has an idea about my problem or an address in order to fine the map, it could be great!
Thank you all
I had this problem after the thugs nicked my CD player. I just took it to a specialist and got it done for £20. was worth the hassle, i suppose
Sie
Black 96P Cinq Sporting
arent fiat's wires a bit different than the standard iso connections?
Met Cognac 99 Brava 100 HSX, wish it'd clean itself!
