| valve stem oil seals How the feck do you remove the old ones? I dont know if its just my oil ones in my new head being akward or what, but whenever i try to pull them out as it says in haynes manual it just bites off a little chunk of the plastic and the rest remains. The pic in the haynes shows them really exposed, but that must be the 899 head.So, how can i remove the old crusty valve stem oil seals?
| Wide arch Hormann Turbo | Re: valve stem oil seals long nose pliers. Ive got some long nose pliers that are perfect and I have done many valve stem seals with them. If you have too much more trouble I dont mind coming and giving you a hand as I see you are in Kent. Rich.
| | #3 | ||
| Re: valve stem oil seals Thats what ive been using, just when im gripping and pulling up, they're just falling apart as it would seem the plastic has disintegrated. Think i may just carefully split them with a scalpel. Not sure what other options there are Cheers for the offer though
| | #4 | ||
| Principality Retained :) | Re: valve stem oil seals VERY CAREFULLY use a chisel and a hammer.
| Instructions for oil change | Koa | Leisure Lounge | 3 | 15-04-2006 03:49 |
| | 899man | Cinquecento / Seicento | 8 | 10-01-2006 21:50 |
| Valve Stem Seals | jamesbeaman | Ulysse | 1 | 12-06-2005 23:43 |
