| Hi, I have a Seicento s (not sporting) and would like to fit a regular sporting rev counter. I've seen some threads that say there is a 4 pin connector beneath the dash but when I took off the centre heater panel I could'nt see anything! Please help.
| | #3 | |||||
| custodian of imola blue | Re: Rev Counter In Seicento S
I see no reason whatsoever why the Sporting rev counter shouldn't work, but it ain't going to be easy as both the dash and the harness are subtly different.
| | #4 | ||
| Re: Rev Counter In Seicento S Thanks for the quick reply I never thought it would be so difficult...
| | #5 | ||
| Formerly mog1571 | Re: Rev Counter In Seicento S i looked at this a while back, you have to cut the dash and noones managed it so im guessing the wiring harness is different.
__________________ Previous 2005-2007 - 2001 Capri blue seicento SX Current 57 plate GP active sport, action red, Sporting front fogs, JBL Sub and amp. | ||
| | #6 | ||
| Re: Rev Counter In Seicento S If there is no 4 pin connector then I guess you'd need to cut through the dash and into the engine bay..then a ground, +ve 12V and engine pulse and attach those to the sporting tacho. Sounds quite tricky!
| | chaos | Cinquecento / Seicento | 137 | 12-04-2007 19:19 |
| | Pauluk | Punto | 20 | 28-04-2006 17:55 |
| | fannon | Punto | 0 | 28-02-2006 20:03 |
| | Matt925 | Cinquecento / Seicento | 2 | 04-01-2006 20:58 |
| | puntostyling | Punto | 2 | 16-12-2004 10:35 |
