| ' | Anyone know the main engine coolant pipe internal diameter? I need to order an adapter to fit my temperature sender. I am going to fit it in the main engine coolant outlet. However I need the car on the road till i do it so i need to know what the internal diameter of the tubing is?? I pressume its the same on a cinq or Sei. The very rough external circumference of the tube is 11cm, which gives a diamater of approximatly 35mm. however you can buy these in 30mm, 32mm, 34mm, 36mm. I therefore need it quiet accurate, and with my rough measurments and not knowing the wall thinkness, I can't just guess. If you think a different size sender somewhere else would be better, just let me know ![]() Cheers for ya help Kristian
__________________ Black Seicento Sporting mk2 1242cc 16V conversion finished and removed! ![]() Megasquirt installed, a constant evolution 1368cc and 6 speed running great now ![]() My Members Motors thread ![]() | ||
| MG ZR Owner :) | Re: Anyone know the main engine coolant pipe internal diameter? I used a clamp size 29mm-41mm but can't remember the internal diameter although I think its 32mm, but best get that confirmed.
| | #3 | ||
| ' | Re: Anyone know the main engine coolant pipe internal diameter? Cheers for ya help It comes with the clamps anyway, but one guess at 32mm is a help ![]() Kristian
| | #4 | ||
| ' | Re: Anyone know the main engine coolant pipe internal diameter? One and only bumpty bump No body else got any idea?? If not i'll get the 32mm, and pray, lube or silicone seal if it's the wrong size Cheers, Kristian
| | #5 | ||
| Rip'n'Burn | 1st time I've seen this particular thread, so just in case people don't spot Kritip's comments elsewhere (See his Guide for example: http://www.fiatforum.com/cinquecento...e-fitment.html ) I now own his old made up pipe with 32mm RAID adaptor for the sender - it fits in the pipe but as He did warn me, it looks like 30 would be far less of a squeeze into the pipe!!! On a positive note, I'd guess it should mean less restrictive flow? Oh, as is mentioned elsewhere make sure if the gauge has an earth lead that it is linked to one on your T-piece adapter & that you fit a cable leading to an earth (handy unpainted screw) on the chassis - THE DIAGRAMS THAT CAME WITH MY GAUGE WERE HORRIBLE!!!
__________________ That which does not kill us makes us stronger!!! | ||
| | #6 | ||
| ' | Re: Anyone know the main engine coolant pipe internal diameter? Yeah, it was a squeeze, but the ID of the adapter is probably the same size as the ID of the tubing, so no restriction. It lasted a long time, and no leaks or tears, and the tube has now taken on the form of the adapter My gauge diagrams were a nightmare also, and I have a degree in electronics lol I never earthed the adapter at all. just ran two wires from it to the gauge, and and earth from the gauge to the chasis. How long till you fit it then? this weekend? Kristian
| | #8 | ||
| ' | Re: Anyone know the main engine coolant pipe internal diameter? very nice water, oil, egt, ?,? Your not turboing this one are you? Kristian
| | #9 | ||
| Rip'n'Burn | Maybe, if I get chance - have done the gauge install into my central heater vent, I'm just not looking forward to the moment I cut into the rev counter leads!!! Point of no return in the wiring stakes!!! I've gone for Coolant Temp' & Voltage 'cos I wanted to be able to monitor the temp' especially as the car gets older & figured while I was at it I may as well make it up for 2.
| | #10 | ||
| ' | Re: Anyone know the main engine coolant pipe internal diameter? use scotch locks to save cutting. not as pro, but will do the job
| | #11 | |||
| this is where i stand | Re: Anyone know the main engine coolant pipe internal diameter?
(cinq already has water temp )i'll turbo it one day, once(if) i ever get it running as an n/a. fitting the turbo to this engine will be a pretty easy upgrade as the ECU will have no issues dealing with boost, and i already have 4 injectors.
__________________ | |||
| | geom | Uno | 38 | 24-12-2007 08:39 |
| | kebab | Punto | 6 | 30-08-2005 08:45 |
| Fiat Multijet Wins Engine Of The Year Award | doblo | Lets Talk FIAT | 23 | 09-06-2005 22:25 |
| | chrisunoman | Uno | 13 | 23-12-2004 01:15 |
| My X1/9 twin cam conversion | fiatfactory | X1/9 | 2 | 19-08-2004 13:59 |
