The FIAT Forum
Old 16-08-2006   #1
99sei's Avatar
Trader Rating: (1)
99sei has donated! United Kingdom
compression test
right im going to do a compression test on my car to see if ive got a bent valve, causing the over fueling, but whats the size of the hole that you screw the spark plugs in to?
Originally Posted by 99sei
im ginger and special
and now im terrorising the roads in my cinq
99sei is offline
Old 16-08-2006   #2
Trader Rating: (0)
Re: compression test
1. a bent valve wont cause over fuelling
2. you will find it very hard to bend a valve on a fire engine as the piston and valves dont occupy the same space like most engines
nogin is offline
Old 16-08-2006   #3
99sei's Avatar
Trader Rating: (1)
wont it cause a smell of fuel to come out the exhaust though?
thats what im getting, as the fuel isnt getting burnt.
99sei is offline
Old 16-08-2006   #4
Funny saying here
jamie86's Avatar
Trader Rating: (1)
jamie86 has donated! United Kingdom
How does the car run?
Checked all the plugs are sparking?
Checked HT leads?
Etc...
Originally Posted by A wise person
Mini invented the giant killer, VW started the genre, Ford & Vauxhall Desecrated it, but the Peugeot 205 GTi was undoubtedly the king of the breed.
jamie86 is offline
Old 16-08-2006   #5
umop apisdn
balidey's Avatar
Trader Rating: (1)
balidey has donated! United Kingdom
If you are doing a compression test, all the kits i have ever used had a selection of threads on the pipes, so it should'nt matter what the plug size is, there should be the correct pipe in the kit.
Your sister is hot, but your mum does that thing with her tongue
balidey is offline
Old 16-08-2006   #6
99sei's Avatar
Trader Rating: (1)
ok cheers baildey
jamie - all new plugs and leads, changed the coil pack.
it runs ok then will get a little miss fire another 20 secs later the same
99sei is offline
Old 16-08-2006   #7
Principality Retained :)
Trader Rating: (3)
arseofbox has donated! United Kingdom
arseofbox is offline
Old 16-08-2006   #8
99sei's Avatar
Trader Rating: (1)
cleaned and put back in, will try another this week. cleaned it with a baby wipe, would that have been ok?
think i might have killed the cat with the constant overfueling though
99sei is offline
Old 16-08-2006   #9
Trader Rating: (3)
Cleaning wouldnt have helped if its broken!
Cat may be dead yes.
Bear in mind that the lambda is only switched into the ECU once it starts in closed loop operation (once the engine reaches certain conditions)....so that initial 20 secs of ok running may be open loop (usually overfuelled to heat up the engine), then it may go rough as the lambda is switched in, and found to be dodgy.
Also, the lambda probe failing doesn't cause the ECU warning light to come on....
Old 18-08-2006   #10
99sei's Avatar
Trader Rating: (1)
got a compression test done today and.....
no compression at all HG has gone
would this have caused the smell of fuel?
99sei is offline
Old 19-08-2006   #11
Fehler in alle Teilen
Fivehundred's Avatar
Trader Rating: (0)
Fivehundred has donated! United Kingdom
That can't be right, if it has no compression at all it won't run, and head gaskets don't normally cause catastrophic compression loss, that's burnt out valve, broken rings holed piston territory. If one pot has no compression put a bit of oil down the bore. If you then see compression its rings, no change it's valves.
Fivehundred is offline
Old 19-08-2006   #12
99sei's Avatar
Trader Rating: (1)
we tried plugs 1 3 and 4 no compression in any
we took the spark plug out, put the compression thing in and fired it up. is that what you do?
it runs, can get good power out of it when on the road. but emissioins are too high and the smell of petrol from the exhaust.
99sei is offline
Old 19-08-2006   #13
arc
this is where i stand
arc's Avatar
Trader Rating: (0)
arc has donated! United Kingdom
you don't fire it up, no. Pull the HT leads off remove the plug of what you're testing, and put the tester in. turn it over on the starter a few times, the tester should record the peak pressure reading.
If you had no compression in 3 out of 4 cylinders, it wouldn't run.
arc is offline
Old 19-08-2006   #14
Trader Rating: (0)
PMSL, The procedure is to check with the throttle wide open. You remove all the plugs from the engine, pull the connectors off the coil packs so the coils aren't firing. The person turnung the engine open holds the throttle wide open. Then test the compressions one by one. You should get readings within 10% of each other on all 4 cylinders. The compression reading itself isn't that important, within reason, mainly because the gauges tend to be inaccurate. You do want conformity however.
Pete
Old 19-08-2006   #15
Trader Rating: (0)
You don't need to open the throttle if the plugs are all removed. There won't be any significant manifold suction as the air can enter down any of the spark plug holes.
You can leave the throttle wide open if you want, but as it spings closed it can be inconvenient.
Malin Dixon is offline
(T) DISCUSSION Thread: Stilo Secret Menus & Settings Access Sticky Rich Stilo 16 22-07-2008 22:03
Compression Testing Trancendental Tipo 6 02-07-2006 09:41
(G) Test drove GP sporting today! 1.8Stilo Grande Punto 10 28-06-2006 21:34
Failed My Driving Test! B****X cheekychento Leisure Lounge 21 08-12-2005 23:55
Compression failure. Morty Mort Lets Talk FIAT 25 12-07-2004 23:49
