The FIAT Forum
Old 09-08-2006   #1
carlhunter88's Avatar
Trader Rating: (0)
Gear Knob
Hello,
I have recently been given a new alloy gear knob as a present for my 99 reg Seicento, and i am having a real big problem actually fitting it into the car!
Ive searched on the forum and found basic instructions, for example, hacksawing the factory moulded gear knob off, but i am at a loss on how to do it.
Can anyone suggest any ways to remove the moulded knob? as am a bit stuck
Thanks! (first time poster!!! )
Owner of...
Fiat Seicento SX Orange V Reg (99)!
carlhunter88 is offline
Old 09-08-2006   #2
i am
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: Gear Knob
its different on the sei over the cinq but im not sure how.
for a cinq you lower the leather gaitor
undo the nut securing the reverse cable
withdraw the pin that passes through the gear shaft
lift of the the gearknob assembly
thats from memory though
custard is offline
Old 09-08-2006   #3
Trader Rating: (0)
Re: Gear Knob
oh right... i will give that a try tomorrow, thanks custard!
can any sei owners or anyone with any knowledge of taking the gear knob off a sei please give any advice!
why oh why cant it be as easy as the gear knob instructions? turn knob anticlockwise... as if! lol!
Owner of...
Old 09-08-2006   #4
RIP L181 VBB
AppleSei's Avatar
Trader Rating: (4)
AppleSei has donated! United Kingdom
Re: Gear Knob
This thread may help you it has a few pics, if anything will give you an idea what things will look like etc.
http://www.fiatforum.com/cinq-sei-st...-gearknob.html
Cinq and sei sportings have same style gearknob custard.
As this is an SX sei i think it is a different style of gearknob altogether and isnt lift up reverse as well.
You may need the OMP adaptor if not already got one.
Hope this helps.
If you can i think we would appreciate some sort of guide, in picture and word form for future reference for everyone if thats ok
2001 Modded Sei Sporting - GONE!!
1998 Ford Mondeo 1.8LX - P/X'ed
2002 02 Ford Focus 1.6 Zetec w/ Climate Pack!
AppleSei is offline
Old 09-08-2006   #5
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
Re: Gear Knob
On a Sei it's simpler than a Cinq. There's no reverse inhibitor cable. You need a hacksaw, a sharp stanley knife and a big flat screwdriver.
Unpop the press stud at the top of the gaitor and push the gaitor down, securing it out of the way with selotape or something. Working inside the car, make a cut from side to side through the top of the gear nob until you hit metal. Make two cuts through the softer plastic from top to bottom of the knob, meeting up with the cut through the top. Insert screwdriver in cut and, supporting the gear lever, lever the screwdriver until the hard plastic cracks and the lot falls off (you may have to tap one half with a hammer). That's it.
All this because the knob is actually molded onto the lever and retained, not by glue, but by a waisted section. The outer surface of the knob is in a softer plastic than the harder body of it and appears to be molded on top of that. All in all, a clever peice of production engineering, but a PITA to remove.
fingers99 is offline
Old 10-08-2006   #6
kritip's Avatar
Trader Rating: (3)
kritip has donated! United Kingdom
Re: Gear Knob
Is that the same techique for the Sei Sporting leather knob? Not that I plan on changing mine, but I am curious if that also needs to be trashed to remove it?
Kristian
Black Seicento Sporting mk2
1242cc 16V conversion finished and removed!
Megasquirt installed, a constant evolution
1368cc and 6 speed running great now
My Members Motors thread
kritip is offline
Old 10-08-2006   #7
fingers99's Avatar
Trader Rating: (1)
Re: Gear Knob
More or less, but I've an idea that some Sportings have a push down for reverse mechanism which may make life more complicated. Of course, they've also got leather in place of or as well as (the soft) plastic.
If the car has push down reverse it's easy enough to do without it, but may mean getting the gearchange mechanism from an S or SX.
My S has a Sporting gearbox.................
Old 10-08-2006   #8
i am
custard's Avatar
Trader Rating: (1)
Re: Gear Knob
thats where the OMP adapter comes in
custard is offline
(S) Gear knob changing was easy. seongtaek Marea 1 17-02-2006 22:14
(S) Fitting Non-lift up Reverse Gear knob 2 Punto OXCiD3 Punto 1 28-10-2005 19:28
(S) Gear Knob Replacement polecat Marea 0 15-02-2004 23:09
(S) Gear Knob Pete600 Cinquecento / Seicento 10 08-05-2003 05:33
