| Clubcento Member | Head require skimming? OK a preview of what I’m up to but need advice. I’ve taken the cylinder head off from my 66k mile engine and am just seeking opinion on if it requires a face re-skim? Also, would it be recommended to take a wire brush headed dremel to it to get off the carbon deposits or would that be considered damaging to the aluminium face? P.S I wasn't a head gasket failure. ![]()
| Re: Head require skimming? A skim on this head is an absolute must. I also would pressure test it. I f you haven't done anything on heads, leave the Dremel where it is. Th carbon deposits might partly go with a solvent. Otherwise the help of a fairly soft tool will do the job. But it should be coming back clean from the machine shop.
| | #4 | ||
| ***** Friendly | Re: Head require skimming? bloody hell! your making me scared to look at mine now
| | #5 | ||
| ' | Re: Head require skimming? Skim is pretty cheap though CHeaper than a lot of stuff that could need doing ![]() Why are only the heads skimmed though generally, just cause they are smaller and warp easier?? Kristian
__________________ Black Seicento Sporting mk2 1242cc 16V conversion finished and removed! ![]() Megasquirt installed, a constant evolution 1368cc and 6 speed running great now ![]() My Members Motors thread ![]() | ||
| | #6 | |||
| __________ | Re: Head require skimming?
__________________ Binki | |||
| | #7 | ||
| ' | Re: Head require skimming? Exactly what I meant gathering knowledge all the time ![]() KRistian
| | #8 | |||
| mad bad and very very old | Re: Head require skimming?
Fire engines run through a very difficult duty cycle. Thrashed from cold. The Coventry Climax fire pump engine thrived on thrashing from cold. When they were fitted into racing cars and were warmed up 'properly', the bores glazed over and let all the oil out. Cheers D
__________________ If it has pistons or tits, its going to be expensive. | |||
| | #9 | |||
| The Thrill of Driving.... | Re: Head require skimming?
He was also the UK Cars & Car Conversions UK Rally Champion in an Imp with the racing engine of 998cc IIRC beating the bigger engined Minis and on more than one occasion the Escorts etc from the bigger divisions on way to title. Recently read a book on the Imp, even Alex Isaggonis the MINI man knew it was a better car than the Mini, but it was rushed out early as the Mini was further into its development and didn't want to lose to many sale s to it, consequently underdeveloped and had initial problems, tho sure you remember these being a wee bit older than me
__________________ ![]() 1992 Lancia integrale EVO1; 1995 Toyota Celica GT4 ST205; 2001 Seicento Abarth 1.4 16V 6speed (OK that one's Emma's) | |||
| | #10 | |||
Back on topic, Hindle's in Bradford charge £15 to skim the head. So there's no excuse really. John
__________________ BIG Fiat... now on Facebook | ||||
| | #11 | ||
| Re: Head require skimming? if the head gasket didnt go you dont need it skimming but it would be better to get it done if you dont get it done use a blade to get the old gaskit off then rub the surface using emery tape you dont need to have it cleand after about 1 hour it will build up again inside but if the head gaskit went get it checked if its worped or cracked then if its ok get it skimmed/preasure tested/ and you might aswell have some new valve stem seals if its done lots of miles
| | #12 | |||
The common cures involved:- 1) move the radiator to the front 2) Wills ring the block and head and do without a head gasket. Silly thought. Is wills ringing an option for FIRE engines. Cheers D
| | #13 | |||
Remember them!!! I had a Sunbeam Stiletto. That was the coupe version with twin headlamps and twin carbs. ('Twin Carbs' for young persons are a wee bit like MPi over the standard SPi system, exept they allow the flow of more air havng more openings) Cheers D
| Die Hard!!! | The Negotiator | Leisure Lounge | 27 | 24-04-2006 22:20 |
| | andyr | Punto | 16 | 17-04-2006 18:48 |
| | Celt | Marea | 1 | 15-04-2006 13:20 |
| | pubcrawler | Punto | 5 | 22-07-2005 10:54 |
| A tale of two head gaskets. | John H | Panda (Classic) | 17 | 22-04-2005 21:26 |
