| dead cinq Hi all, I seem to have killed my cinq. How i do not know, but the electrics are very very intermittant. Majority of the time it works fine, but has its off moments - ie you go to turn the key and nothing works - completely dead. This usually only lasts a short time before kicking back into life and it works as if nothing had happened. But today it did it and stayed like it, completely dead. I managed to jump start it off my mates car battery in the end, so my suspicions lie with the battery. If it is, how comes it can go from fine to dead in such a short time? I have no electrical drain on it, and it can last days without problems, or 5 minutes before killing over again. I originally thought it was a grounding wire somewhere, but i stripped them all down today and all was fine. I fiddled with the electrical connectors etc too and they were all tightly connected. So has to be battery right? 1 abarth cinq up for sale very soon
| meow | Re: dead cinq its totaly wrecked, im running a scrappy service now, il pay £20 per car
__________________ [b]Next car? punto again? ![]() Long term project car- Punto 55 Previous car- Uno turbo | ||
| | #3 | ||
| Re: dead cinq dud battery dude?
__________________ ![]() Van Aaken High Boost Turbo Cinq In Caribean Orange, Highly Modded | |||
| | #4 | ||
| custodian of imola blue | Re: dead cinq I think it's unlikely to be the battery itself. But it's easy enough to get a battery tested. I'd be inclined to suspect the battery connections (if it doesn't start, try tapping the connectors with a hammer). Otherwise, I'd look at the earth connections (try running one jump lead from the -ive battery to the engine) and then inspect all the larger positive cables. Make 'em spotless, bare metal to bare metal and coat them with vasolene or silicon grease. Do the other electrics work? How long before the headlights (on main beam) go dim?
| | #5 | ||
| ...done | Re: dead cinq sh*t man... sounds nasty, not the alternator given up the ghost?
__________________ R97 cinq 1242 <Ex Team Anthracite > (now sold) | ||
| | #6 | ||
| ' | Re: dead cinq Sounds like an earth or +ve connection/cable problem to me also. Do you have a multimeter avalible to you for continuity/resistance and voltage checks?? Kristian
__________________ Black Seicento Sporting mk2 1242cc 16V conversion finished and removed! ![]() Megasquirt installed, a constant evolution 1368cc and 6 speed running great now ![]() My Members Motors thread ![]() | ||
| | #7 | |||||
| Re: dead cinq
The other electrics were dead. Everything goes completely dead. Interior light would come on fine to start with ignition off, but would go off completely as soon as you put key in and turned on all accessories. As soon as you put it off again the interior light would work again. Although after about 10 minutes that went really dim. Definately not the alternator Mase, i put a brand new one on last october time when my old one seized up completely. All i can put it down to is duff battery or terminals. Ive just been out and bought a new battery and new terminals, so will see if that cures the problem. if not i shall cry into a chilled beer and feel sorry for myself
| | #8 | |||
| mad bad and very very old | Re: dead cinq
Cheers D
__________________ If it has pistons or tits, its going to be expensive. | |||
| | #9 | ||
| i am | Re: dead cinq check the cables,wondering if you have a break in the main cable somewhere | ||
| | #10 | ||
| Re: dead cinq well ive just fitted the new battery and put new terminals on the wires, and all seems well again. How long that lasts, time will tell. But at least it starts first time now with no signs of gremlins.
| | #11 | |||||
| Re: dead cinq
| | #12 | ||
| i am | Re: dead cinq yeah but even slight movements may have re connected it. hopefully 'just' a battery Luke(no numbers) | ||
| | #13 | ||
| Re: dead cinq i would try starting the car then dissconect the batt then if it cuts out then its you altonator if it dosent its ok i would check the charging rate aswell using a multimeter it should be around 10 volts turn on your lights and heater and anything eles just if its over charging the batt will be no good in a week.
| | #14 | ||
| i am | Re: dead cinq if you disconnect the battery you break the cars power circuit | ||
| | #15 | |||
No no and eh NO. Never run the alternator with the battery disconnected. Cheers D
