The FIAT Forum
Old 02-08-2006   #1
Cornish Cinque
AIJ29's Avatar
Trader Rating: (0)
AIJ29 has donated!
Fuel pipe question
Hi Guys
I`m just finalising my mpi conversion and have come across a little snag,
The punto 75 fuel rail has a thread to which the inlet fuel pipe threads onto(the fitting is crimped on by the factory),On the cinq its just a push on pipe with a jubilee clip,Could i replace the whole rubber pipe on the cinq and fit the pipe from the 75
Adrian
AIJ29 is offline
Old 02-08-2006   #2
kritip's Avatar
Trader Rating: (3)
kritip has donated! United Kingdom
Re: Fuel pipe question
Not exactly sure what you mean, but as long as it fits, doesn't leak and you keep the ID (Internal Diameter) of the hose the same size or greater, so as not to restrict fueal flow all will be good
Kristian
Black Seicento Sporting mk2
1242cc 16V conversion finished and removed!
Megasquirt installed, a constant evolution
1368cc and 6 speed running great now
My Members Motors thread
kritip is offline
Old 03-08-2006   #3
Trader Rating: (0)
i exspect the mpi is done that way as you have i think 3.5 bar of fuel pressure which i would not like a jubille clip holding
nogin is offline
Old 03-08-2006   #4
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Check out the Rally Design website for fuel hose and ends. Its the safest way.
D
rallycinq is offline
Old 07-08-2006   #5
Cornish Cinque
AIJ29's Avatar
Trader Rating: (0)
AIJ29 has donated!
Hi Guys
It`s a specific connector,I cant seem to find one anywhere.
This is a piccie of a punto 75 powered cinque that belons to chevaler from france.
It`s the factory fitting from a punto 75 but must connect to the cinque fuel system some how
Adrian
Name:	fuel connector.jpg
AIJ29 is offline
Old 10-08-2006   #6
Asteris's Avatar
Trader Rating: (0)
Greece
My sei's pipe is fitted directly to the Punto75 fuel rail and holded in place with a jubille clip for more than 9 months now. No problems till now...
Asteris is offline
Old 10-08-2006   #7
rallycinq's Avatar
Trader Rating: (1)
Originally Posted by AIJ29
Hi Guys
Adrian
Couldn't get a smaller picture could you?
All these years of abuse, I can't see the connector clearly enough, sorry.
D
Old 10-08-2006   #8
arc
this is where i stand
arc's Avatar
Trader Rating: (0)
arc has donated! United Kingdom
D
heres a couple of better pics, not bad for camera phone photos eh
ID:	17350  Click image for larger version
arc is offline
Old 10-08-2006   #9
rallycinq's Avatar
Trader Rating: (1)
Super, thanks.
http://www.goodridge.net/uk/pdf/Good...alogue2005.pdf
should help
D
Old 14-08-2006   #10
Cornish Cinque
AIJ29's Avatar
Trader Rating: (0)
AIJ29 has donated!
Hi
Just a quick reply to my own question,
Might be of use to the guys doing mpi conversions,
I had another look at the fitting today and realised i could probably cut off the crimped section,
I clamped the nut part in a vice and very carefully (using a junior hacksaw) cut down the crimp in a couple of places until i could peel the crimp off the fitting,You have to be very careful when cutting as you don`t want to damage the tube in the centre of the crimped section,
I now have a fuel fitting that will be easy to push into the cinque fuel pipe,
I`ve spoken to a friend of mine that rallies a 180bhp 1.8 16v k series mini,and all he uses to attach his fuel pipes is 2 jubilee clips per connector and says this has never given him any problems in 2 seasons of rallying so i`m going to try that method before splashing out on aeroquip fittings
Adrian
AIJ29 is offline
Old 14-08-2006   #11
Cornish Cinque
AIJ29's Avatar
Trader Rating: (0)
AIJ29 has donated!
Hi
This is the crimp i removed with the hacksaw
Adrian
AIJ29 is offline
Old 14-08-2006   #12
i am
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
similar crimp on the cinq OE pipes.i removed them the same way when replacing flexi pipes
custard is offline
(T) Fuel question TheCROW Bravo / Brava 12 11-04-2006 09:01
Airplane fuel - Question. christopher watson Leisure Lounge 20 26-03-2006 17:23
(T) 899cc Fuel Tank - AGGHHH!!! Sei-Mad Cinquecento / Seicento 19 10-10-2005 01:35
fuel pipe werdna Panda (Classic) 2 05-04-2005 19:13
(T) OH CRAP!!!!! FUEL LEAK!!!!!!!!!!!!!!! Damo Cinquecento / Seicento 14 15-01-2004 06:19
