| Engine Swap...ecu As Well? Hi, I've just fitted a Punto 1242cc 8V engine into my Cinq. sporting, using your superb forum for all the help that I needed! I also obtained the Punto wiring loom and ECU. It is obviously mapped/ programmed for the Punto engine, so is there any advantage in using this ECU? I notice that the ECU connector plugs are not compatible, but I am sure that I could work out the wiring from circuit diagrams.. Another strange occurance :- I have two Cinq. sportings and the ECU in one of them just wouldn't allow the fuel pump to run... no way! So I swopped them between the two cars, with the result that the first car now DID work and the fuel pump ran, BUT SO DID THE OTHER, WITH THE APPARENTLY FAULTY ECU !!! Well, can ANYONE give me an explanation for that, please? .... because I haven't got a clue! thanks for your help.....David
| this is where i stand | Re: Engine Swap...ecu As Well?
__________________ | ||
| | #3 | ||
| Re: Engine Swap...ecu As Well? Hello Arc, It DID appear to be just a fauly ECU, but when I simply swapped them between two cars, the apparent faulty ECU worked O.K. in the OTHER car!. I just can't explain it! No immobiliser fitted, I think..... the extra key that I got on the ring must have been a mechanical locking device! Thanks for showing such an interest in my "woes"!!
| | #4 | ||
| Scandinavian Passion.... | Re: Engine Swap...ecu As Well?
__________________ Daily Driver: Seicento Sporting, Dark Grey, MPI 1108cc 8v, stock externals Track Day: Seicento Sporting, Yellow, High Boost 1247cc 8v, Factory Abarth body kit Luxury Liner: Volvo V70 D5 Sport, Black, chipped & uprated intercooler, V70R body kit | ||
| | arseofbox | Bravo / Brava | 13 | 29-03-2006 18:24 |
| Multipla engine swap... | drnino | Multipla | 4 | 21-06-2005 07:53 |
| Need an engine cable harness ECU connector | luximax | Multipla | 1 | 27-11-2004 18:30 |
| | my cinq now | Cinquecento / Seicento | 51 | 10-11-2003 02:46 |
