The FIAT Forum
Old 28-07-2006   #1
α ψΨψ Ω
alainax's Avatar
Trader Rating: (0)
alainax has donated! United Kingdom
purply bits
any body know where i can get purple engine bits?
you know hoses n induction kit etc.
ive looked but cantr find much
links would be greatly appreciated!!
xxx
alainax is offline
Old 28-07-2006   #2
polecat's Avatar
Trader Rating: (0)
polecat has donated! United Kingdom
Re: purply bits
Samco do silicon hoses in purple. One supplier below.
http://www.performancecentre.co.uk/p...__01&PTC=HOS22
EDIT... Link does'nt work. Try link, then search by brand, then samco....
Not sure what car kits are available though.
polecat is offline
Old 28-07-2006   #3
α ψΨψ Ω
alainax's Avatar
Trader Rating: (0)
Re: purply bits
thanks thats perfect!!!
xxx
alainax is offline
Old 29-07-2006   #4
paulbfd's Avatar
Trader Rating: (0)
paulbfd has donated! United Kingdom
Re: purply bits
www.tastynuts.com
For anodised nuts & bolts (in none critical locations!).
Black 100HP
Alpine CDA-7944, PXA-H701 processor and RUX-C701 controller.
Hertz Mille MLK2 components, Mille 10" subwoofer and HP4 amplifier.
Chord Epic speaker cable and Anthem RCA leads.
paulbfd is offline
Old 29-07-2006   #5
α ψΨψ Ω
alainax's Avatar
Trader Rating: (0)
Re: purply bits
what different size of tube mm will i need for the cinq engine?
xxx
alainax is offline
Old 29-07-2006   #6
α ψΨψ Ω
alainax's Avatar
Trader Rating: (0)
Re: purply bits
Originally Posted by paulbfd
www.tastynuts.com
mmmm ordred stuff for bike (bad alaina )
xxx
alainax is offline
Old 29-07-2006   #7
i am
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: purply bits
speak to ghostwkdid the turbo in yellow samcos.
okay you wont need all he did but should have some sizes for you.or its a case or removing & measuring.
see ive always wondered on these things why people dont do all these things pre respray to avoid working over the new paint as much as possible
custard is offline
Old 31-07-2006   #8
α ψΨψ Ω
alainax's Avatar
Trader Rating: (0)
Re: purply bits
meh.............. coz in my eyes its prettyness before performance
xxx
alainax is offline
Old 31-07-2006   #9
Moderation in Moderation
GhostWKD's Avatar
Trader Rating: (0)
GhostWKD has donated! United Kingdom
Re: purply bits
http://www.fiatforum.com/leisure-lou...t=yellow+samco
remember a couple of the measurements were a smidge off but i had enough hose there to sort it out
Lots of mods Rev1 MR2 Turbo - Sold pending collection
RX7 Twin Turbo - Because real men play with twins
GhostWKD is online now
Old 31-07-2006   #10
α ψΨψ Ω
alainax's Avatar
Trader Rating: (0)
Re: purply bits
MY hero
now to avoid me having to ask ross n seem all blonde any chance you could take away the parts the turbo needs but i wont?? thanks
38mm ID 90 deg hoses, 102mm leg x3 (boost pipe)
38mm ID 90 deg hose, 152mm leg x1 (boost pipe)
44mm ID 135 deg hoses x2 102mm leg (induction pipe)
25mm ID straight 76mm long (for dumpvalve fitting)
25mm ID straight 1metre (oil breather pipe)
19mm ID straight 1m length (coolant pipe from the 4 block to the expansion tank)
10mm ID straight, 1m length (top of expansion tank to the throttle body)
8mm ID straight, 3m length (vacuum pipes and general bay tidyup)
alainax is offline
Old 31-07-2006   #11
i am
custard's Avatar
Trader Rating: (1)
Re: purply bits
2 boost pipes and dump valve pipe can go.induction pipe depends on your set up
also oil breather pipe depends on set up
custard is offline
Old 31-07-2006   #12
GhostWKD's Avatar
Trader Rating: (0)
Re: purply bits
25mm ID straight 1metre (oil breather pipe) - depends on induction setup
19mm ID straight 1m length (coolant pipe from the 4 block to the expansion tank) - depends if you want to fit that one, its slightly on show though lol
10mm ID straight, 1m length (top of expansion tank to the throttle body) - The very visible one lol
8mm ID straight, 3m length (vacuum pipes and general bay tidyup) - replace your vacuum hoses
for your induction kit pipes etc it'd all depend on your setup and cant think of much else at the mo anyway :P
Old 31-07-2006   #13
Whats the point....
Trader Rating: (0)
h2ypr has donated! United Kingdom
Re: purply bits
38mm ID 90 deg hoses, 102mm leg x3 (boost pipe) not needed
38mm ID 90 deg hose, 152mm leg x1 (boost pipe) not needed...
44mm ID 135 deg hoses x2 102mm leg (induction pipe) not needed
25mm ID straight 76mm long (for dumpvalve fitting) not needed
she has a k an n induction kit....... will she need these ones?
What colour of induction kits can she get? she wants purple!
Ross
h2ypr is offline
Old 31-07-2006   #14
i am
custard's Avatar
Trader Rating: (1)
Re: purply bits
Ross
custard is offline
Old 31-07-2006   #15
GhostWKD's Avatar
Trader Rating: (0)
Re: purply bits
ross, check out bushboys old induction kit he had on his old black one (1 of lol) had a custom plenum with blue samcoy bits iirc, can do that but with purple
(G) still got plenty of bits lads. deaduno Uno 8 4 Weeks Ago 00:16
(G) spare bits kicking around arc Cinquecento / Seicento 16 12-10-2005 01:29
