Do all Bravo discs fit onto a Sei Sporting?... I feel a little case of overkill coming on :devil:
uno turbo rear beam is it not?StoneNewt said:Fronts for sure... may do a rear disc conversion latter on...
charlieboy said:uno turbo rear beam is it not?
has alex done his on the cinqT yet?
punto_jr_sx75 said:They literally swap dont they? all you need to do is make pipes up for them.
Jordan
Luke1985 said:Not beam as the cinq retains its rear wishbone setup, just you use the UT rear hubs, caliper mounts and calipers...
alainax said:thier so hard to get a hold of!! been searching for a few days now, gonna do the rear disk conversion as soon as i get all the parts.
( cosmetic purposes mainly lol!)
so its just hubs, mounts n calipers, which disks are best with this set up?
xxx
Asteris said:Ok, here's the deal for rear disk conversion on a cento.
Calipers from Uno turbo/Punto Gt (they are the same)
Plate from Uno turbo, fits straight
Disk 228mm from Uno turbo
Hub from Uno turbo
Straight fit, no modifications needed, cento handbrake cable mounts with no problem.
You can also use the 240mm disk (cento's front, Punto GT rear, Alfa 155 rear etc), with same calipers and without changing hub, if you fabricate a custom plate based on the Uno's plate, only the two holes the caliper mounts on have to be 6mm further out.
I have them almost a year now, no probs with the handbrake, no better stopping power, but you can break inside a turn without fearing for the weels to lock unexpectedly. Oh, and far better looks of course...
Luke1985 said:Tell me about it, i looked for a good couple of months before giving up and putting all new standard stuff on. Alex did the same also.
You're probably best off with just standard solids and pads on the rear as you dont want to have too much breaking force on the back or you'll be asking for trouble. You *may* find you need to alter the brake bias valves too if it still locks up on standard stuff.
alainax said:new stuff? are the parts available???
xxx
