The FIAT Forum
Old 25-07-2006   #1
pranksta's Avatar
Trader Rating: (0)
Engine swap
Just want to clarify this, been looking throught threads about doing a 1242cc engine swap and was just wanted to know if im correct in thinking that the 1242 8v fits straight in the cinq, but the 16v needs some slight adjustment as well as the alternator repostioning.
<a rel=http://www.fiatforum.com/gallery/data/500/New_Sig1.jpg" border="0" />
pranksta is offline
Old 25-07-2006   #2
i am
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: Engine swap
yes but theres the wiring to consider with the MPI as well.
custard is offline
Old 25-07-2006   #3
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Re: Engine swap
1242 8v into cinq is a straight swap with only an exhaust spacer required.
16V is the one that needs the wiring change and some clearance issues adjusted.
D
rallycinq is online now
Old 25-07-2006   #4
hi friends :waves:
Liam's Avatar
Trader Rating: (0)
Liam has donated! United Kingdom
Re: Engine swap
Been covered a tonne of times before, 8v SPI is straight forward and the 16v is a nightmare!
Liam
CINQ SPORTING WING MIRROR IN BLACK FOR SALE O/S
97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND
Liam is offline
Old 25-07-2006   #5
Twin Spark power!
Duncan's Avatar
Trader Rating: (0)
Duncan has donated! Italy
Re: Engine swap
Liam
8v MPI is also trickier than the SPI, generally the harder the swap the more power gains though.
1999 Alfa Romeo 146Ti & 1996 Alfa Romeo 155TS 16v
Duncan is offline
Old 28-07-2006   #6
JR
Trader Rating: (0)
Italy
Re: Engine swap
The16v conversion is not as hard as people think, once the wiring looms ecu is sorted, which with an uncoded ecu is not too bad.
I would go for mpi 8v as a compromise- much more tuning potential than spi, spi has just had more development at the mo being the older engine setup on the cinqs/seis. There is so much more to be obtained from the mpi engines.
JR is offline
(T) urgant engine swap calvins_tipo Uno 41 16-07-2006 12:00
(T) 1242 engine swap vandisian Cinquecento / Seicento 25 13-06-2006 02:54
(T) engine swap cost + clutch problem distortionrockets Uno 23 15-01-2006 18:31
Multipla engine swap... drnino Multipla 4 21-06-2005 07:53
(G) Punto engine swap Cinq_Sport_BiG_DaVE Cinquecento / Seicento 3 24-09-2004 12:45
