The FIAT Forum
Old 24-07-2006   #1
Trader Rating: (0)
Angry injecter light
Hi Guys,Just bought a p reg cinq sporting,as i was driving along today the injecter light came on and it stays on.The car is misfiring as if it is running on 3 cylinders.Pulled off number 2 ht lead and there is no spark.Is it ECU?
bhola is offline
Old 24-07-2006   #2
VW Polo 1.9 TDI Sport
Trader Rating: (0)
chris4500uk has donated! United Kingdom
Re: injecter light
Dont think it would be the ecu, more like the coil pack or maybe the lead itself?
chris4500uk is offline
Old 24-07-2006   #3
i am
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: injecter light
coil would be the 1st thing to check.
you can swap the coils over(there 2) and see if the non spark cylinder moves
custard is offline
Old 24-07-2006   #4
Trader Rating: (0)
Re: injecter light
ive change the leads over just to try and its still number 2 cylinder,where r the coils located,are they hard to change?Cheers
bhola is offline
Old 24-07-2006   #5
i am
custard's Avatar
Trader Rating: (1)
Re: injecter light
when you changed the HT lead.
1 ends on the spark plug and the other the coil.
there are 2 so you can swap them over and see if the fault moves.
custard is offline
Old 24-07-2006   #6
M*0*USE
sikersh's Avatar
Trader Rating: (0)
sikersh has donated! United Kingdom
Re: injecter light
Before buying new coils, check the LT leads that plug into each coil, as this was the problem with mine (after buying new coils, HT leads etc!!)
Mine were all 'bubbled' at the end of each wire (before they go into the actual plug) and when I touched them slightly to one side the engine would cut out and misfire suggesting it was them, a quick nip to a scrappies and cut some off a Punto for a measly £2.00, cut old ones off, connect & solder new ones, plug into coils and bobs yer uncle!
It's worth checking these first before forking out for the expensive stuff.
Si
sikersh is offline
lol Donz Leisure Lounge 76 17-09-2007 13:37
(T) Fuel injecter light Maharg Punto 0 21-06-2006 21:40
(T) Boot Light not working... wotnowarninglight Stilo 7 21-03-2006 14:12
(T) Oh No, The Forum Curse, Injecter Light PhatAshKi Cinquecento / Seicento 12 23-10-2004 16:51
[Tipo 1.6 ie 94] Injection light and idle Malex Tipo 1 28-07-2004 21:18
