The FIAT Forum
Old 24-07-2006   #1
Trader Rating: (0)
window trim
window trim has recently fallen out.i can push it back in by hand but as soon as the windows go down out it comes again,really annoying as i cant use my passenger window.anyone know how to sort this?and is it a window out job?
shepz is offline
Old 24-07-2006   #2
i am
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: window trim
is it the one along the bottom of the glass or around the door frame?
custard is offline
Old 24-07-2006   #3
RIP L181 VBB
AppleSei's Avatar
Trader Rating: (4)
AppleSei has donated! United Kingdom
Re: window trim
If you mean the one at the bottom, then you can put it back on by hand, but you have to take your doorcards off to do it.
It is also a very fiddly job.
2001 Modded Sei Sporting - GONE!!
1998 Ford Mondeo 1.8LX - P/X'ed
2002 02 Ford Focus 1.6 Zetec w/ Climate Pack!
AppleSei is offline
Old 25-07-2006   #4
Trader Rating: (0)
Re: window trim
ooops bottom sorry should have said,il have a look at it today not looking forward,fidelyness
shepz is offline
Old 25-07-2006   #5
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Re: window trim
Two things, you have to clip it down, and then in towads the panel to make it stick. Secondly, clean any kaka off it and lubricate it to stop the glass dragging it up.
D
rallycinq is offline
Old 30-07-2006   #6
The Ugly Duckling's Avatar
Trader Rating: (0)
Re: window trim
If it's just the rubber bit, just push it back in. You don't need to strip the door down or anything. It does take a bit of time, but isn't too difficult. I tried replacing the whole plastic bit, but after stripping most of the door I couldn't work out how to replace it.
The Ugly Duckling is offline
Old 30-07-2006   #7
RIP L181 VBB
AppleSei's Avatar
Trader Rating: (4)
Re: window trim
Disagree.
This is the bottom section rubber, once the electric window button is pushed to raise or lower, if you push it back in or out it pops straight back out again as it isnt anchored down properly and has come off its main section on the inside of the door.
The doorcard has to come off, my mechanic had to take the doorcard off in order to re connect it on the inside.
AppleSei is offline
Old 30-07-2006   #8
Trader Rating: (0)
Re: window trim
Originally Posted by AppleSei
Disagree.
Well, my one has been working perfectly for the last few weeks since pushing it in I don't care what people say, it is clearly possible, at least in some cases
Old 31-07-2006   #9
Trader Rating: (0)
Re: window trim
mine used to be like that...used to hardly ever pop out....used to be a monthly occasion,but now everytime the window go's up and down it pop's out.no doubt you'l have that to look forward too
shepz is offline
Old 31-07-2006   #10
i am
custard's Avatar
Trader Rating: (1)
Re: window trim
must admit mine popped out once in the non turbo and with a bit off faffing went back into place and has been there for 2 years
custard is offline
Die Hard!!! The Negotiator Leisure Lounge 27 24-04-2006 22:20
Driver's side window Nudgeman Bodyshop 4 30-11-2005 14:37
(T) Marea ELX Driver's Electric Window Stuck OilBurner Marea 2 04-08-2005 01:31
(T) Electric window jambo Punto 7 09-08-2003 20:39
