| Formerly mog1571 | creaking clutch cable ok my clutch cable has been creaking for a while, as far as we can tell its where the cables attached to the metal arm at the clutch side. so was just wondering is it safe to put some grease on it? im guessing i would have to take it all apart to get the grease in properly.
__________________ Previous 2005-2007 - 2001 Capri blue seicento SX Current 57 plate GP active sport, action red, Sporting front fogs, JBL Sub and amp. | ||
| | #3 | ||
| Formerly mog1571 | Re: creaking clutch cable it snapped a few months back and has been creaking ever since the new one was fitted, i just think it needs a bit of grease which they never put on
| | #4 | ||
| Re: creaking clutch cable I've recently replaced my clutch cable, and new new one has been creaking like yours. I don't know what's causing it.
| | #5 | ||
| Join Date: Jun 2003 Location: Malpas, Cheshire, United Kingdom.
Thanks: 0 Trader Rating: (0) | Re: creaking clutch cable Sounds like the pressure plate on the clutch is on the way out, cinq clutches should be fairly light
__________________ Steve Wright If it doesn't make it go faster its just ballast http://www.chestermodels.com/fiat http://www.offroading.net | ||
| | #6 | ||
| Re: creaking clutch cable people always go for the worst thing they can think of first, i have had a new clutch and mine started to creak bout weel after and it has been doing it ever since 1 year and counting so just squirt some lub in the general direction till some thing bad happens or not like me
| | #7 | ||
| custodian of imola blue | Re: creaking clutch cable Try some aerosol grease or spray chain lube (motorbike shop) spraying "up" the cable sheath while someone works the pedal up and down. It may or not fix the creak, but is handy for gearshift and brake cables, too.
| | 4paws | Uno | 10 | 23-03-2006 15:56 |
| | AIJ29 | Cinquecento / Seicento | 3 | 20-05-2005 23:08 |
| | SnowBord | Cinquecento / Seicento | 12 | 13-02-2005 18:18 |
