| taffy git | my hub nut meant to look like this have been concerned about this since seeing it last time i had the wheel off, i have only now had the chance to take the wheel off again, so took some pics is the hub nut meant to look like this please put my mind at ease or not ![]() on the plus side my washer bottle now keeps water in it , have also managed to get rear squirter working - but i dont really need it cause i not got a wiper ![]() EDIT - sorry these pics are on the big side
__________________ Gaz Marea Weekend | ||
| TruBlu | Re: my hub nut meant to look like this mine don't look like that, its just looks like a normal nut, ie. it don't have that bit sticking out forward. On the second pic it looks like its been undone at some point coz of the marks on it - your not supposed to re-use them, you ever had it off?
__________________ ![]() | ||
| | #3 | ||
| Re: my hub nut meant to look like this No expert, but it looks to be missing a split pin.. Don't compromise, get it to a garage for an opinion. 2 second job.
__________________ 2000 Plate JTD, Elx Punto 3 Door It's bog standard The Subaru Legacy was amazing... I don't like | |||
| | #4 | ||
| TruBlu | Re: my hub nut meant to look like this Mine doesn't have a split pin but i see what you mean. If it is torqued properly though that shouldn't matter too much. If it worries you then you could change it - Gaz if you do decide to change it you might as well do the wheel bearing at the same time, 5 min job on the back
| | #5 | ||
| __________ | Re: my hub nut meant to look like this they dont have a split pin, they do have the sticking out bit, the sticking out bit gets bashed into the grooves to stop the nut coming off, if you got no bits in the grooves, then it will undo an fall off
__________________ Binki | ||
| | #6 | |||
| taffy git | Re: my hub nut meant to look like this
__________________ Gaz Marea Weekend | |||
| | #7 | |||
new ones are about £4
__________________ Binki | |||
| | #8 | |||
| | #9 | ||
| i am | Re: my hub nut meant to look like this when you get a new one gaz its just a nut but with a long extended collar round the top.once fitted you stake it on both sides over the groove on the drive shaft. should be renewed whenever removed. yours looks well abused edit:you dont need to whack it so hard it splits the metal,all your doing is bending the metal into the grooves to revent it undoing itself | ||
| | #10 | |||
, i dont want to destroy the carthanks for the help peeps
| | #11 | ||
| i am | Re: my hub nut meant to look like this honestly gaz its easy.just torque the nut down then put a flatscrew driver on it and hammer the handle to stake it | ||
| | #13 | ||
| i am | Re: my hub nut meant to look like this ach ive got my big screwdriver/lever/remover/punch/nose picker screwdriver for these jobs | ||
| | #14 | |||
![]() i really dont fancy changing the nut as it is an important part of the car
| | #15 | ||
| Re: my hub nut meant to look like this They are tight 240N/m which once they have been staked are difficult to get off, best way, remove the staking, remove centre from wheel, reattach wheel to car, and then enjoy, 32mm socket required and a very big bar, or a good impact driver.
__________________ The 'Green Hell' seemed more like Heaven to me | |||
| | Jamieboy | Cinquecento / Seicento | 10 | 20-02-2006 00:00 |
| | Slippy | Cinquecento / Seicento | 6 | 14-12-2005 01:50 |
| | catchy | Punto | 0 | 07-12-2005 11:00 |
| | TheBogieMan | Cinquecento / Seicento | 8 | 21-09-2005 18:07 |
