The FIAT Forum
Old 04-07-2006   #1
getcarter's Avatar
Trader Rating: (0)
Saver wheel heating up
So my friend asked me 'can I have a drive in your car on this private road'. She's had forty lessons, so I said yes. She clearly hasn't had the 'why you should avoid potholes' lesson now, and I'm in desperate need of a new alloy and tyre.
HOWEVER, after fitting the saver wheel and driving back to London from Kent I noticed that the wheel itself was getting very very hot - does this seem normal to anyone else?
getcarter is offline
Old 04-07-2006   #2
i am
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: Saver wheel heating up
what speed were you driving?its a smaller tyre so will generate more heat compared to the others
custard is offline
Old 04-07-2006   #3
Trader Rating: (0)
If my memory serves me correctly space savers shouldn't be used at speeds above 50mph and only used for a short distance of 50miles. i could be wrong with this esimate but only thing i can think off
xracer is offline
Old 04-07-2006   #4
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
I presume you didn't exceed the 50mph limit for these tyres.
D
rallycinq is offline
Old 04-07-2006   #5
VW Polo 1.9 TDI Sport
Trader Rating: (0)
chris4500uk has donated! United Kingdom
Standard sporting alloys come up on ebay from time to time, also in the classifieds
chris4500uk is offline
Old 04-07-2006   #6
The Ugly Duckling's Avatar
Trader Rating: (0)
I would expect that to be normal, although I've never really checked.
As others have said you shouldn't exceed 50mph, should use it for no more than 50miles, and I would recommend taking things easy. It won't perform as well as a normal tyre! So, with your journey you were probably at risk of something like a blowout
The Ugly Duckling is offline
Old 05-07-2006   #7
getcarter's Avatar
Trader Rating: (0)
No, I didn't go over 50 on the way back, and the journey was about 40 miles or so, so I'll have to get a new saver wheel...! I was just concerned about the temperature of the actual wheel as opposed to the tyre.
Old 05-07-2006   #8
Jamieboy's Avatar
Trader Rating: (0)
Is it fitted to a rear wheel? If so, another possibility could be a binding brake. The heat generated by friction could conceivably conduct to the rim.
2000 Punto 1242 MPI in Tiziano Red Standard (for now)
Jamieboy is offline
Old 05-07-2006   #9
Just another nutter
Munkul's Avatar
Trader Rating: (0)
Munkul has donated! United Kingdom
wel, i know on my front alloys they heat up after a fast journey (not so much distance but braking and speed) cause of the heat generated by the brakes. i wonder if this applies here?
Munkul is offline
Old 05-07-2006   #10
hot hot tamale!
Hellcat's Avatar
Trader Rating: (3)
Hellcat has donated!
Did you run the space saver on the front or rear axle? I would have thought putting it on the rear would have kept it cooler, and helped with the braking etc.
I've driven on a Tipo space saver for well over 50 miles at over 50mph and it wasn't even inflated fully. It was 2am and I'd got a puncture on the England/Scotland border in heavy snow in December!
Hellcat is offline
Old 05-07-2006   #11
TruBlu
blu73's Avatar
Trader Rating: (0)
blu73 has donated! United Kingdom
car make any whirry noises, could be a wheel bearing on the way out causing heat. Perhaps put the space save on a different wheel and go for a small drive see if it gets as hot?
blu73 is offline
Old 05-07-2006   #12
getcarter's Avatar
Trader Rating: (0)
There has been a squeaky from that front right which I had presumed was the brake rubbing - a light dab on the brake would stop it as would steering. However, this stopped when the spacer was fitter.
Does anyone know any good breakers yards near London then? Any recommendations?
Old 07-07-2006   #13
Formerly mog1571
Luke M's Avatar
Trader Rating: (2)
Luke M has donated! United Kingdom
that squeking you hear is what i had a few months back, discovered my brake pads were VERY low and down to bare metal in places, this was also causing alot of heat on the bolts and wheels.
think thats your problem!
take off your wheels and look at the pads and discs, check theyre not low!
Previous 2005-2007 - 2001 Capri blue seicento SX
Current 57 plate GP active sport, action red, Sporting front fogs, JBL Sub and amp.
Luke M is offline
(S) space saver wheel Luke M Cinquecento / Seicento 19 27-01-2006 18:47
(T) Space Saver Spare Wheel kjlith@ntlworld.com Stilo 10 10-08-2005 13:14
