| Unknown noise in front end?Cinquecento L/Reg High all,newbie "gilly" here! i am having a noise problem at the front of my fiat cinquecento:here`s the prob,when i approach a traffic light or junction on a steep hill,and then brake,then disenguage clutch,i keep getting a noise simular to a "rusty" old fan coming to a slow stop!then when i set off again it sounds like cranking up an engine using the old type of cranking handle.However when i reach a speed of say 20 to 30 mpg the noise goes away,and it doesn`t appear again the rest of the day.It seem more prevelent when the car has been "idle" overnight.i am sorry i can`t be more discriptive,but i am a little worried,my m.o.t is due end of the month!Any advise would be much appreciated,kind regards,Jeff.
| ' | Re: Unknown noise in front end?Cinquecento L/Reg Sounds very odd but associated with the clutch. Maybe its not disengaging fully :S Try adjusting it anyway, its really easy In the engine bay, pasasnger side near the front is a threded rod, with a plastic nut that you can turn by hand. Give it a good 5 or 6 turns, not sure which way. This will adjust the clutch and your biting point, but may help with the problem?Kristian
| | #3 | |||||
| | thefishdude | Punto | 7 | 23-12-2003 23:28 |
| | broadfield | Punto | 5 | 07-11-2003 20:00 |
| | broadfield | Punto | 13 | 05-11-2003 22:29 |
| | christos | Stilo | 5 | 25-06-2003 22:22 |
| | syphon123 | Cinquecento / Seicento | 2 | 01-03-2003 02:11 |
