| FF Party Animal | Argh!!!! MOT Failure :( I cant believe it. Its failed on more than i thought it would have i knew the rear brakes were crap. so gonna give them a look to see if they can be adjusted at all. but also the lambda sensor is knakered and it needs a rear bush or full real arm.if theres anyone on here that has a spare lambda kickin about oh and a rear bush or suspension arm theres money waiting any help is apprecieated as its not bin on the road for the best part of 6 months now and shes dying to be driven if she was well
__________________ The One & Only Little Red Devil!! Dont Be Fooled By Imitations | ||
| Re: Argh!!!! MOT Failure :( iv got a spare lambda, pm me
| | #3 | ||
| FF Party Animal | Re: Argh!!!! MOT Failure :( well im part way thru trying to sort the brakes after trying for 2 hours to remove one brake drum. and thaks to scott for sortin me out with a lambda. im not sure what to do as far as the rear bush is concerned though. do i get a new or newer full rear arm for the left side or do i try and fit a new bush? i know pete has fitted poly rear bushes to his but how easy is it to do? and is it worth it? so this is how she stands at the mo with her rear end about 2ft off the floor
| | #4 | ||
| mad bad and very very old | Re: Argh!!!! MOT Failure :( If you fit a second hand rear arm, you will be faced with doing it again next year at MOT time, probably. So bite the bullet and do itv right the first time, polybush them both. Cheers D
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #6 | |||
| meow | Re: Argh!!!! MOT Failure :(
__________________ [b]Next car? punto again? ![]() Long term project car- Punto 55 Previous car- Uno turbo | |||
| | #7 | |||
Cheers D
__________________ If it has pistons or tits, its going to be expensive. | |||
| | Maisy | Punto | 13 | 25-05-2006 23:25 |
| | Steven | Cinquecento / Seicento | 9 | 14-05-2006 13:27 |
| MoT emissions failure | pinkpunto | Tipo | 2 | 14-12-2005 11:31 |
| | Will Gardner | Bravo / Brava | 2 | 19-01-2005 15:57 |
| | cazz | Bravo / Brava | 2 | 10-09-2004 18:32 |
