| Cinqs & Chester Jets rock | I need a crank sensor Mobile mechanic came out to look at red cinq today, pulled everything about and found out it isn't the ecu as diagnosed by the recovery man. Apparently the pulley near the timing belt was loose, the metal on metal sound I heard was a lump of metal caught up that had spun around and sheared off the top of the crank sensor. The sensor will need to be smashed out and replaced with another. Relief in one way cos it was hinted at that it might be the head gasket, but that has been eliminated now.
| | #3 | ||
| hi friends :waves: | Re: I need a crank sensor Not ideal but could the wire be bodged neatly if such a thing exists with the duff sensor and donor sensor? Liam
__________________ CINQ SPORTING WING MIRROR IN BLACK FOR SALE O/S 97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND | ||
| | #4 | ||
| Cinqs & Chester Jets rock | Re: I need a crank sensor Thanks guys. Knew you'd have some parts hanging around Dave. Would a Sei one be the same? Rang my sister to see if she still had the 899cc one, but it went with the rest of the engine. Can the crank sensor be replaced easily as a DIY job - bearing in mind it will need to be broken out? PS. Dave you were right about Fronteras!!!!!
| | #5 | ||
| i am | Re: I need a crank sensor very easy.1 bolt at the sensor and a plug at t'other end.if the one dave has,has a shorter cable then extend its length with cables with male/female spades as a temp fix | ||
| | #6 | ||
| __________ | Re: I need a crank sensor sei one should fit he wont want a lot for it, dont smash the old one out you may brake the mount, just cut a bit off so its flush with the mount, remove bolt and it will cone out easy
__________________ Binki | ||
| | #7 | ||
| Cinqs & Chester Jets rock | Re: I need a crank sensor Great - might have a go myself then. Could you let me know how much your mate wants for the sensor Dave? Thanks
| | #9 | ||
| Principality Retained :) | Re: I need a crank sensor The 899cc TDC sensors are totally different to the ones on the FIRE powered models
| | #10 | ||
| Cinqs & Chester Jets rock | Re: I need a crank sensor Oh!! Shows how much the mobile mechanic knows then he told me they were exactly the same.
| | #11 | ||
| Cinqs & Chester Jets rock | Re: I need a crank sensor Any luck Dave?
| | #12 | ||
| __________ | Re: I need a crank sensor didnt get up there my going to the scrappy car is stuck behind daryls and he didnt come home to push it out the way my punto is too low to go through the farm
| | #13 | ||
| Re: I need a crank sensor same as what my cinq needs probs just go to fiat and get one me thinks aswell as gettin another cinq this week me thinks!
| | #14 | ||
| Cinqs & Chester Jets rock | Re: I need a crank sensor I know what you mean about getting another cinq!!!! Didn't want to buy the part new, apart from being mean it would be my luck it isn't the crank sensor after all!! Plus, being a student I need cheap and cheerful.
| | #15 | ||
| Re: I need a crank sensor iv got 2 i think. pm me if you still need one
| Tempra 1.6 SW Crank Sensor | BrianM | Tempra | 3 | 17-06-2005 19:56 |
| | shabz1981 | Punto | 6 | 23-11-2004 00:05 |
| | vman | Marea | 0 | 28-09-2004 10:39 |
| | GeX | Cinquecento / Seicento | 3 | 08-09-2004 00:43 |
| | oaksey | Marea | 4 | 01-09-2004 15:39 |
