The FIAT Forum
Old 12-06-2006   #1
99sei's Avatar
Trader Rating: (1)
99sei has donated! United Kingdom
rear drum brakes with pics question
right been doing the left rear drum brake today as it was stuck. now ive got the cover off (broke a clip in the process)
looked at the apd things and they look in good nick to me, everything does, apart from one thing
pics of rear drum brakes (look really clean to me, from other threads ive read) and the pad things look new, what do you lot think?
[IMG][/IMG]
and now the thing im confused about, the pad thing dont sit all the way in where the piston groove is, yet the other side does is this right?
[IMG][/IMG]
Originally Posted by 99sei
im ginger and special
and now im terrorising the roads in my cinq
99sei is offline
Old 12-06-2006   #2
ate too much
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: rear drum brakes with pics question
push the shoes in and they will.
the friction material on the shoes is a bit low.you didnt have to take the hub off
custard is offline
Old 12-06-2006   #3
99sei's Avatar
Trader Rating: (1)
the thing was sticking and wouldnt turn, would these pass the mot?
Thanks for the quick reply
99sei is offline
Old 12-06-2006   #4
ate too much
custard's Avatar
Trader Rating: (1)
doesnt matter for mot as long as the brakes work to the set % inc handbrake but you may find oyu wont have enough adjustment if the shoes are worn
custard is offline
Old 12-06-2006   #5
99sei's Avatar
Trader Rating: (1)
ahh ok thanks for the info. will put it back on for the time being and try an mot with it as it is. the cinq wont be on the road afta the mot so dont matter. just tried to move the friction plate, but it wont move in to that little grove any suggestions?
99sei is offline
Old 12-06-2006   #6
hi friends :waves:
Liam's Avatar
Trader Rating: (0)
Liam has donated! United Kingdom
Check for leaks around the cylinders and free up the handbrake levers and adjust the cable accordingly and you should get a decent brake for the MOT.
Liam
CINQ SPORTING WING MIRROR IN BLACK FOR SALE O/S
97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND
Liam is offline
Old 12-06-2006   #7
99sei's Avatar
Trader Rating: (1)
no brake fluid as of yet still got to do that, will have a little play though.
cheers for the info
99sei is offline
Old 12-06-2006   #8
99sei's Avatar
Trader Rating: (1)
right ive had a play but the drum still wont move, i think its down to the friction pads. the handbrake is off, not that it works any way. the other part of the drum will spin freely with out the drum on but when the drum is put on the friction plates stop the drum turning.
what have i got to do next?
99sei is offline
Old 12-06-2006   #9
ate too much
custard's Avatar
Trader Rating: (1)
when you have the drum off have you tried pushing the shoes in by hand on both sides?
after fitting my new shoes mine dragged until i fitted new springs.guess the old springs let the shoes fit too far out
custard is offline
Old 12-06-2006   #10
99sei's Avatar
Trader Rating: (1)
trie one side but not both
new though about the springs being too loose will go have a look again now
cheers
99sei is offline
Old 12-06-2006   #11
ate too much
custard's Avatar
Trader Rating: (1)
cheers
why one side?if you push both sides you can centre them rather than having them to one side
custard is offline
Old 12-06-2006   #12
99sei's Avatar
Trader Rating: (1)
tried to get the friction plate in so i only pushed one side. tryied both side now an neither will move. should both the things that the friction plates slot in to both move inwards?
any way had a little play and i can get it to spin freely with out the hub on again. put the hub on and it still moves fairly freely start putting the two little bolts on and it slows down, start tightening the nut and it back to square one very little movement
so this must rule out the springs as it moves freely around them when not tightened, so my thoughs are its catching on some thing. rubed down both the hub and the backing plate to get rid of rust, still the same
99sei is offline
Old 12-06-2006   #13
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
rallycinq has donated! New Caledonia
Late into this one, and i'm a wee bit lost about the different hubs that you seem to have.
Firstly, mount up the hub, the bit with the bearing in it. That should spin freely. Leave it on.
Make sure the drums have no lip on the inner edge, if so, grind it away.
Try and fit the drum over the shoes. It should go on with a small amount of drag.
If it does not go on, use two large levers, one either side, to skweez the shoes together to allow the drum to just fit. The shoes need to be centred, also using the levers.
Hope this helps
D
rallycinq is offline
Old 12-06-2006   #14
99sei's Avatar
Trader Rating: (1)
thanks for the input rally cinq
hub and bearing spin freely
all lips rubbed away
drum goes over shoes with small amount of drag
then the problem starts, as you tighten the nut it doesnt spin freely, as you tighten even more you cant move it at all
99sei is offline
Old 12-06-2006   #15
Formerly mog1571
Luke M's Avatar
Trader Rating: (2)
Luke M has donated! United Kingdom
sounds like the drum is rubbing on the edge of the shoes
looking at that picture it looks like youve lost one of the clips that holds the shoes in place.
just check the shoes are sat back in place properly
Previous 2005-2007 - 2001 Capri blue seicento SX
Current 57 plate GP active sport, action red, Sporting front fogs, JBL Sub and amp.
Luke M is offline
vB code is On
Seized rear Brakes Phil R Barchetta 20 14-08-2008 20:46
Bloody Rear brakes StiloJoe Stilo > Technical 26 17-08-2007 20:07
Rear Brakes on Multipla's Johnny Boy Multipla 2 27-04-2006 08:29
Rear brakes!!! KK1 Stilo > Technical 23 18-02-2006 07:50
Rear screen question Koa Stilo 20 31-01-2006 18:30
