General turbo fiat cinquecento
simi
rotherham
ok i got a fiat cinquecento still not running lol will a turbo fit and how do i go about doing it. its a fiat cinquecento sx 900cc
click the link in custard boys signiture or do a search absolute hundreds of threads on this :)
Dont think you can get a 900cc turbo, and even if you could, it would be crappy, unless you spent lots of money on it.
Start with a sporting, much better
so i would be better off with a bigger engine then ? what engines fit in this iv been looking on ebay cant find anything bigger.
899, 1108, 1242, and a couple of UT lumps if youve really got cash to speand go for the second two will fit.
The 1108 is a better base to work on if you want to do this kind of conversion
Do a search :) It has been covered plenty of times before ;) For a 899, you're gonna have to change more than the engine - probably better off getting a Sporting :)
correcto!
as you have the 900cc like my sei i thought about going for a 1242 lump but then thought its gonna be as much work to get that in as it is with a Uno turbo lump.
so i got my monies out and went for the 1.3 turbo option :slayer:
at the mo im just doing other things on my car (suspenstion, brakes and ice) but once thats all done i will make a guide of my progress fitting the beast :yum: as no one seems to supply any info on this forum about ut lump fitting (n)
might be happening in about 1-2months time just saving money at the mo incase i come across problems when doing it.
dave said:
to fit the uno lump you need to cut away all the inner wing, and re fabricate it, thats why no one does it. there is a girl on here with one but she not posted for ages
Who else just read that and thought DTM Wide Arches please!
sounds like a big job then think i will have to save up and a think of what to do thanks fo the info
Think a sensible option that Gaz, but im interested to see this occur :)
Slightly off topic, will a 1242 fit in my sei? ;)
fingers99 said:
Yes. Even a 16valve can be squeezed in. There's plenty of stuff on one of the forums about this. Plan to transplant a Punto 75 motor myself (if I don't find a cheap Cinq and an Alfa V6 first.........).
lmao! (y) although read daves post :D
