The FIAT Forum
Old 15-05-2006   #1
Trader Rating: (0)
When should my Seicento Sporting Cambelt be Changed?
Can anyone help, I've had my Seicento 1.1 Sporting for just over a week now and I keep getting conflicting advice from the Fiat Dealership in Shrewsbury as to when my Fiat Seicento Cambelt needs changing. They initially said every 54k miles or 5 years (whichever comes first) and then on a different occasion said every 72k miles because it's on the 12k miles service intervals? It's a Y reg (2001 plate) and has now done 43k miles - In July '06 it will be 5 years old. Does anyone know the real miles or length of time that my cambelt should be changed - also will it totally knacker up the engine if it does snap - I've read a few entry's that say it won't do any damage to the engine?
Regards, Pippypower.
pippypower is offline
Old 15-05-2006   #2
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Re: When should my Seicento Sporting Cambelt be Changed?
The 1108 engine is described as 'safe' in the vent of a cam belt failure. That is little consolation, however, if you are in the fast lane of the M6 during rush hour at the time.
I would be changing it at 5 years max, its not a long job to do, ans I wouldn't want it failing on its terms.
D
rallycinq is offline
Old 15-05-2006   #3
Moderator
Trader Rating: (7)
Steven has donated!
The advice given through experience on the forum would suggest that the belt should be changed at around 50k or 5 years. However the 1.1 engine is a non-interferance engine so it won't be damaged if the belt breaks.
Steven is offline
Old 15-05-2006   #4
RIP L181 VBB
AppleSei's Avatar
Trader Rating: (4)
AppleSei has donated! United Kingdom
i have an 01 on a Y and i had mine done at 35k
2001 Modded Sei Sporting - GONE!!
1998 Ford Mondeo 1.8LX - P/X'ed
2002 02 Ford Focus 1.6 Zetec w/ Climate Pack!
AppleSei is offline
Old 16-05-2006   #5
paulbfd's Avatar
Trader Rating: (0)
paulbfd has donated! United Kingdom
It says in the manual to change it more often if you do "city" driving.
I changed mine @ 4 years / 23,000 miles.
Black 100HP
Alpine CDA-7944, PXA-H701 processor and RUX-C701 controller.
Hertz Mille MLK2 components, Mille 10" subwoofer and HP4 amplifier.
Chord Epic speaker cable and Anthem RCA leads.
paulbfd is offline
Old 17-05-2006   #6
Trader Rating: (0)
If I dont know when the cam belt was changed on any of the cars ive owned I have always done it. least then u know its done
The engine may not be damaged by a failed cam belt but its still an aggravation thats easily and relatively cheaply avoided
Yellow_peril is offline
Old 23-10-2006   #7
Trader Rating: (0)
Hi, didn't want to start a new thread so thought I'd ask on this one as its what I wanted to know. My cars just passed 40k (cant believe I've done 14k miles since buying feb 2005) anyway since its a 2000 V reg I figured it was time to get my cam belt done. Just rang my local AA service centre although I think there owned by nationwideautocentres now they want £210 to change it. This seems well harsh, anyone on here know where i can get it done for a reasonable price. Being a student i cant afford to be paying out such a huge amount.
satty is offline
Old 23-10-2006   #8
rallycinq's Avatar
Trader Rating: (1)
Haynes manual and a cam belt kit, DIY.
D
Old 23-10-2006   #9
Trader Rating: (0)
I think i have a haynes manual for this well actually its for the cinquento but i think the engine is the same. Is it a really easy thing to do as im not very mechanically minded. Probably do something wrong and be without a car. I'm assuming I get the cam belt kit from Fiat, what does it include and how much is it?, Anyone have the product code?
I was hoping I could get it done for under £100 somewhere.
satty is offline
Old 23-10-2006   #10
Eats, shoots & leaves
col7104's Avatar
Trader Rating: (1)
col7104 has donated! United Kingdom
You can do it yourself without much trouble at all! If you get stuck or unsure half-way through then the forum's always open. I got my kit from shop4parts. Consists of a tensioner bearing and belt.
I had to however get the belt changed as there's two pitches you can get. My engine was the lower pitch of the two and I got sent the higher one. Easiest thing to do is go to your local FIAT, give them your chassis number and they can give you the appropriate kit. It's around £20 I think.
The job took me, well, it took me a few days but that's because I was waiting for the correct belt, but actual working time I would say no more than 2 hours. At first I thought, no way could I do a cambelt, but after a thousand miles it's still running perfect! You can too!
May as well do the alternator belt while your there too, it comes off anyway.
In the way of tools, a spanner set (for alternator), torque wrench, 7,8 and 10mm sockets (for various parts) will be pretty much all you need. The torques will be in the Haynes for the various parts. May as well replace the tensioner bearing nut with a nylock nut when it's off, can get that from any DIY store.
Disconnect the battery, chock the wheels and jack the drivers side of the car up, whip the wheel off and support on axle stands (the car, not the wheel). Remove the arch liner, there aren't any hidden nuts so just remove all the one you see and it shoul be free to move. I couldn't actually fully remove mine (although I'm told if you tug hard enough it does come out) so I just bent it and used the disc/caliper arrangement to hold it back. Now you can see the rabbit (you are the dog). Working from the top, take the top belt guard off, (mine was held in by one bolt on the back of the head). This forms half of the cover, the bottom part will still be held in from below. Now, working from below, slacken the alternator nuts off with a spanner. Slide the alternator toward the block to make the belt go slack. Remove belt. Now, undo the three bolts holding the crank sensor pulley (the pulley the alternator belt went around) on. Remove said pulley. Now you can undo the bolt holding the lower part of the belt cover on, and remove it and the cover.
The new belt comes with two seperate white or yellow lines, simply have to make these correspond with the marks on the pullets. Before you take the old belt off, turn the engine over to TDC on cylinder 1 by lining the mark on the crank pulley with the mark on the engine block, pictures of these marks are available in a sticky thread in the Punto tech section.
Slacken off tensioner bearing and remove belt, be careful not to move the top or bottom pulley now (don't worry, their not very easy to move, and won't rotate by themselves), the water pump pulley can be wherever you want it.
Change the tensioner bearing by fully unscrewing the nut, and sliding the bearing off the stud. There are a further two components for the bearing (which will come out when you take it off), but these will be straightforward to refit just by looking at them. Refit (with the nylock nut if you so desire). I couldn't get a torque wrench up there, but 28Nm will be sufficient (basically not much at all). Don't tighten the nut just yet, still have to get the new belt on.
Thread the new belt back on around the pulleys, making the timing marks on the belt correspond wth the marks on the pulleys. Trust the markings between belt and pulley, more than the markings between pulley and block. If you have fitted it correctly, the timing marks will both line up exactly, don't stop until they do. To help me see the marks on the belt, I tippexed a mark on the side of the belt (where the timing mark on top is), so I could see side-on where the mark was.
Now, using a suitable instrument (I used a spanner), lever the bearing (against something solid like the block) against the belt, until you can turn the belt through 90 degrees (comfortably) at the mid point of the longest part. You shouldn't need freakishly strong fingers to turn it through 90 degrees. It's easiest to get a second set of hands to maintain the pressure on the tensioner, while you feel the belt and say "a little more", or "a little less", to the second set of hands. Then, tighten the tensioner bearing nut to the torque described above.
Now, using an appropriate socket, turn the engine over (using the socket on the centre bolt of the crank pulley). It will be easier to do this with the plugs out. Turn the engine through 2 complete revolutions to check that there are no obstructions (shouldn't be anyway if the timings out as it's a safe engine). Refit the crank sensor plate (toothed golden circular thing), noting the hole in the plate lines up with the pin in the crank pulley. The torque (off the top of my head) is 62Nm. The alternator belt doesn't need to be on just yet, we're just making sure the engine runs. Re-connect the battery, refit the plugs (if you took them out), and make sure the engine bay and especially area around the belt is clear from any tools, parts, etc. Now try and start the engine. It should fire and run just like before, if not better. You don't need to do a prolonged test, just see if it runs ok, then turn it off - don't want a flat battery and a hot engine to finish the job with!
Now take the crank sensor plate back off again, and refit the plastic belt cover (maybe you can get it back on with the pulley in the way, but it would be waaaay easier to just take it off again). Now refit and torque it correctly.
Fit a new (or the old) alternator belt between the two pulleys, and again, using a suitable instrument (and/or a second set of hands) , lever the alternator out to make the belt go taught. Tension so that you can push the belt down (or up if you want) 5mm with firm thumb pressure. Now tighten the bolts with your spanner. Good luck in getting a torque wrench up there so I just did them up tight (you should be able to gauge what is right when you slacken them off in the first place).
Refit the top end belt guard/s, then refit the arch liner. Et voila, reconnect battery and away you go (after refitting the wheel, lowering the car to the ground, not before taking the axle stands away).
This is for an SPI Sei however, I believe yours may be MPI. It isn't all that different. Think I also heard the MPIs are a little tight for space under there too. I think you may have a crankshaft sensor of some sort on the top end, should be intuitive to overcome these differences.
HTH
Fix it yourself, learn something and save money!
col7104 is offline
Old 23-10-2006   #11
Trader Rating: (0)
Wow, thats a very good guide. I think I have an SPI. I have a torque wrench, and all the other bits in my tool kit. Armed with a Haynes and your guide im tempted to do this but am worried i'll cock something up. For a complete beginner, who's only ever changed a tyre and some HT leads you think it will take 2 hours. Sucks I cant just pay a mechanic 2 hours labour but i guess they dont work like that.
Im going to order the parts from Fiat tomorrow, a Cam belt kit, plus alternator belt. If i do decide to attempt this, I might do a step by step guide with photos to help other novices like me.
satty is offline
Old 23-10-2006   #12
col7104's Avatar
Trader Rating: (1)
No worries, as I say, the forum's always open with active users so if you do run into troubles you can get a pretty quick answer/fix.
col7104 is offline
Old 24-10-2006   #13
seicento expert in devon
Trader Rating: (0)
fiatseicentoexpert has donated! United Kingdom
Cool Re: When should my Seicento Sporting Cambelt be Changed?
the only problems i have found on the 1.1 fire engines is that, the cam-belts keep brakeing around about the 60,000 - 65,000 mark. thanks, fiatseicentoexpert.
fiatseicentoexpert is offline
Old 28-10-2006   #14
Trader Rating: (0)
Hi
Just about to change my timing belt but had a few last minute questions,
In the haynes manual it says that I need to remove the air cleaner and ducting bits and also the spark plugs. I dont think I have a tool for the spark plugs do you need to remove these? Also the radiator is mentioned for removal as well.
satty is offline
Old 28-10-2006   #15
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
No need to remove the radiator, although removing the fan and shroud may give you a little more room.
To remove the plugs all you need is a spark plug spanner. Your local factor should have one -- and can check it's the right size for a fiver or so.
fingers99 is offline
