The FIAT Forum
Old 07-05-2006   #1
Formerly mog1571
Luke M's Avatar
Trader Rating: (2)
Luke M has donated! United Kingdom
jacking up!
im just wondering wheres the best places for jacking and axle stands on a seicento. i found 4 little round plates by each of the wheels and used them for jacking and put the axle stands on the metal sills but that seemed to bend the sills. anyone got any better suggestions?
Previous 2005-2007 - 2001 Capri blue seicento SX
Current 57 plate GP active sport, action red, Sporting front fogs, JBL Sub and amp.
Luke M is offline
Old 07-05-2006   #2
arc
this is where i stand
arc's Avatar
Trader Rating: (0)
arc has donated! United Kingdom
Re: jacking up!
at the front i use the area where the arb attaches to the suspension. at the rear, i use the main rear cross member
arc is offline
Old 07-05-2006   #3
Formerly mog1571
Luke M's Avatar
Trader Rating: (2)
Re: jacking up!
is there any specific points of the body work you should avoid? i know not to trap brake lines and not use the petrol tank or any of the suspension. is there anywhere else to avoid to not cause damage?
Luke M is offline
Old 07-05-2006   #4
i am
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: jacking up!
well dont do as someone has done on my car in its history and use the sill seam.all crushed up now
mind you the abarth skirts will cover that
custard is offline
Old 07-05-2006   #5
Formerly mog1571
Luke M's Avatar
Trader Rating: (2)
Re: jacking up!
yer ive learnt that! used that last time and its bent now!
Luke M is offline
Old 07-05-2006   #6
custodian of imola blue
fingers99's Avatar
Trader Rating: (1)
fingers99 has donated!
Re: jacking up!
Depends what you want to jack up!
For the whole front use a block of wood and a jack under the sump and put the axle stands under the "boxes by the sills" -- which are the jacking points.
For the back, either use the rear beam (if you've a jack that will reach) or the spring mounts, putting the stand/stands under the jacking points. If you've got a jack -- probably a bottle jack -- you can jack the rear by the jacking points and put the stands on the triangular section where the main floor bends up.
For one side at the front, put the jack at the anti-roll bar to suspension mount, like the man says.
fingers99 is offline
Old 08-05-2006   #7
hi friends :waves:
Liam's Avatar
Trader Rating: (0)
Liam has donated! United Kingdom
Re: jacking up!
I jack the car up at the little plates as you call them then I place my axle stands on the front under the wishbones and just in front of the rear wheels.
Liam
CINQ SPORTING WING MIRROR IN BLACK FOR SALE O/S
97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND
Liam is offline
Old 08-05-2006   #8
RIP L181 VBB
AppleSei's Avatar
Trader Rating: (4)
AppleSei has donated! United Kingdom
Re: jacking up!
isnt there a jacking point on your sei?
2001 Modded Sei Sporting - GONE!!
1998 Ford Mondeo 1.8LX - P/X'ed
2002 02 Ford Focus 1.6 Zetec w/ Climate Pack!
AppleSei is offline
Old 08-05-2006   #9
Formerly mog1571
Luke M's Avatar
Trader Rating: (2)
Re: jacking up!
yer ive found the 4 little points for jacking, those are the discs i spoke about. was more concerned with the axle stands as that seem bends really easily
Luke M is offline
car jacking warning! dave Leisure Lounge 29 30-08-2006 17:06
(T) jacking cinq up? cinquecento_sunderland Cinquecento / Seicento 7 15-12-2005 16:33
(G) Jacking up tgb Marea 9 27-11-2005 19:11
(T) Jacking up The Ugly Duckling Cinquecento / Seicento 1 15-06-2005 21:03
uno jacking points+wheel trims The Negotiator Lets Talk FIAT 5 25-04-2003 03:55
