The FIAT Forum
Old 03-05-2006   #1
Trader Rating: (1)
the beasto has donated! United Kingdom
Exclamation rear windscreen washer (squirter)
the rear washer hasnt been working since ive had my cinq. today my cinq came back from being repaired so im happy, but i thought id do a few jobs on it like hammerite in the rust spots inside the boot.
anyways i had the bonnet open and tried the rear washer and the motor is working but i realised the washer water is squirting out of a pipe in the front of the bonnet through a little hole!! does anyone no what i mean? and how i can fix it?
cheers kris
BEAST
krismaple@msn.com
the beasto is offline
Old 03-05-2006   #2
i am
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: rear windscreen washer (squirter)
im unclear what you mean.where is the 'little hole'?
custard is offline
Old 03-05-2006   #3
Trader Rating: (1)
if you open the bonnet then look left at where you fill the water bottle up?
then theres two pipes comming out of there one of the pipes runs to the right across the front of the bonnet where the catch thingy is that holds the bonnet closed ???
BEAST
krismaple@msn.com
Old 03-05-2006   #4
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Its supposed to be attached to another pipe that goes to the back of the car. It should be attached to a small non return valve, so check out the inner wing on the offside.
D
rallycinq is offline
Old 03-05-2006   #5
fixitagaintomorrow's Avatar
Trader Rating: (0)
fixitagaintomorrow has donated! United Kingdom
Non return valve buggered? Cost about a quid from Fiat.
Pete, Clubcento technical bod.
Links: turbo cinq, Bravo/a/Marea owner's club, Clubcento
fixitagaintomorrow is offline
Old 03-05-2006   #6
Trader Rating: (1)
hhmmmmm i will go and look now
BEAST
krismaple@msn.com
Old 03-05-2006   #7
i am
custard's Avatar
Trader Rating: (1)
mines went on both cinqs so its a common one.mind you about the easiest fix you will ever get
custard is offline
Old 04-05-2006   #8
hi friends :waves:
Liam's Avatar
Trader Rating: (0)
Liam has donated! United Kingdom
Sounds like the pipe for the rear is burst somewhere, follow the pipes from the hole in the inner wing and find the leak and replace the pipe.
Liam
CINQ SPORTING WING MIRROR IN BLACK FOR SALE O/S
97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND
Liam is offline
Old 04-05-2006   #9
Trader Rating: (0)
or the pipe could have slipped off the little plastic t like things....check right at the front of the bonnet(above rad)the hose came off mine....i just slipped it back on and it was sorted
shepz is offline
Old 04-05-2006   #10
VW Polo 1.9 TDI Sport
Trader Rating: (0)
chris4500uk has donated! United Kingdom
Mine has a little copperish pipe that came loose next to the passingers side headlight, thought it was spirting out a light lol.
Check that?
chris4500uk is offline
(S) Updated price list 21/04/2004 Body Stylist Punto 30 09-04-2005 17:02
(G) DJ Bucho is back DJ_Bucho Cinquecento / Seicento 19 14-05-2004 18:41
(T) Heated Rear Window and Headlight washer Pump hatters1999 Bravo / Brava 3 06-04-2004 00:04
(G) Windscreen washer cap DotSPF Uno 6 30-10-2003 21:33
