| Formerly mog1571 | steering column plastic trim ok just tried to remove my speedo in my sei to see if i can do a LED conversion. ive found the bolt at the back by the windscreen and theres 2 on the underneath by the steering column. now i need to take off the trim around the steering column to get to these 2. if anyones looked its in 2 sections a top and bottom. ive managed to get the bottom off where the ignition barrel is but i cant get the top section off! it seems to need to slide backwards because its tucked under the steering wheel but it then hits the speedo! and it wont lift upwards and backwards because seems to be caught somewhere! anyone got any ideas? i cant get the allen keys in with this trim still there!
__________________ Previous 2005-2007 - 2001 Capri blue seicento SX Current 57 plate GP active sport, action red, Sporting front fogs, JBL Sub and amp. | ||
| Re: steering column plastic trim Hi, there are two screws holding the top part or the trim attached to the stalk block just behind the steering wheel. I can't remember if you have to take the steering wheel off or not though!
| | #3 | ||
| Formerly mog1571 | Re: steering column plastic trim i cant remove my steering wheel because its an air bag, theres 2 removable sections which you can take out of the sides of the steering wheel so ill remove them and spin the wheel see if i can see anything. if i find these screws should the top section just lift out? btw this car is MPI not SPI
| | #5 | ||
| Re: steering column plastic trim firstly, disconnect the battery! At the rear of the steering wheel there are two removable covers , Just pop them out and remove the four allen head screws that hold the airbag into the wheel then very carefully disconnect the airbag wire( a fiddley little clip on the later models).
| | #6 | ||
| Formerly mog1571 | Re: steering column plastic trim oh rite! didnt think i could take it off! how do i then get the steering wheel off then? need a special socket or anything??
| | #7 | ||
| Re: steering column plastic trim I can't remember what size it is but it's only about 22mm i think, but be carefull that when it comes loose you don't hit the windscreen with your ratchet.
| | #8 | ||
| mad bad and very very old | Re: steering column plastic trim Undo the steering wheel nut, but leave it on a couple of turns. Before pulling the wheel, mark where it belongs, preferably with a punch mark so you can put it back in the right position. Pull the wheel towards you, try not to jerk it. When it releases from the spline you'll be glad you left the nut on. Saves a face full of wheel. Cheers D
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #9 | ||
| Re: steering column plastic trim Ouch!! I forgot about that little problem.
| | thefishdude | Punto | 0 | 11-10-2005 17:36 |
| | 190daj | Cinquecento / Seicento | 3 | 30-07-2005 18:20 |
| | pjp | Stilo | 7 | 11-01-2005 18:29 |
| | Adamski | Cinquecento / Seicento | 12 | 25-10-2004 00:14 |
| | gfotopou | Stilo | 5 | 15-05-2004 02:56 |
